Differential uniformity and the associated codes of cryptographic functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Mathematics of Communications Année : 2019
Pascale Charpin
  • Fonction : Auteur
  • PersonId : 905949
The associated codes of almost perfect nonlinear (APN) functions have been widely studied. In this paper we consider more generally the codes associated with functions that have differential uniformity at least 4. We emphasize, for such a function F , the role of codewords of weight 3 and 4 and of some cosets of its associated code C F. We give some properties on codes associated with differential uniformity exactly 4. We obtain lower bounds and upper bounds for the numbers of codewords of weight less than 5 of the codes C F. We show that the nonlinearity of F decreases when these numbers increase. We obtain a precise expression to compute these numbers when F is a plateaued or a differentially two-valued function. As an application, we propose a method to construct differentially 4-uniform functions with a large number of 2-to-1 derivatives from APN functions.
ChaPen-2018.pdf (154.13 Ko) Télécharger le fichier
hal-01908336 , version 1 (30-10-2018)
hal-01908336 , version 2 (06-11-2018)
hal-01908336 , version 3 (08-02-2019)
  • HAL Id : hal-01908336 , version 2
Pascale Charpin, Jie Peng. Differential uniformity and the associated codes of cryptographic functions. Advances in Mathematics of Communications, In press. ⟨hal-01908336v2⟩
425 Consultations
453 Téléchargements
