On almost perfect nonlinear functions over F n 2, IEEE Transactions on Information Theory, vol.52, issue.9, pp.4160-4170, 2006. ,
Differential cryptanalysis of DES-like cryptosystems, Journal of Cryptology, vol.4, issue.1, pp.3-72, 1991. ,
Differential properties of power functions, Int. J. Inform. and Coding Theory, vol.1, issue.2, pp.149-170, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00610114
Differential properties of x ? x 2 t ?1, IEEE Transactions on Information Theory, vol.57, issue.12, pp.8127-8137, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00610099
On the equivalence of quadratic APN functions, Des. Codes Cryptogr, vol.61, pp.261-272, 2011. ,
, Binomial differentially 4 uniform permutations with high nonlinearity, Finite Fields and Their Applications, vol.18, pp.537-546, 2012.
Extended-Affine Equivalence, and Function Twisting, Cryptology ePrint Archiv, p.713, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01959749
Boolean and Vectorial Plateaued Functions and APN Functions, IEEE Transactions on Information Theory, vol.61, issue.11, pp.6272-6289, 2015. ,
Codes, bent functions and permutations suitable for DES-like cryptosystems, Des. Codes Cryptogr, vol.15, issue.2, pp.125-156, 1998. ,
On plateaued functions and their constructions, Proc. of FSE, pp.54-73, 2003. ,
On sets determining the differential spectrum of mappings, Int. J. of information and Coding Theory, vol.4, pp.170-184, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01406589
New links between nonlinearity and differential uniformity, proceedings of Sequences and Their Applications, SETA 2018, 2018. ,
DOI : 10.1016/j.ffa.2018.12.001
URL : https://hal.archives-ouvertes.fr/hal-01836184
On binary cyclic codes with minimum distance d = 3, Problems of Information Transmission, vol.33, pp.287-296, 1997. ,
Some new three-valued crosscorrelation functions for binary m-sequences, IEEE Trans. Information Theory, vol.42, issue.4, pp.1238-1240, 1996. ,
, Geometry, codes and difference sets: exceptional connections, vol.10, pp.73-85, 2000.
The weight distributions of the duals of cyclic codes with two zeros, IEEE Trans. Information Theory, vol.57, issue.12, pp.8000-8006, 2011. ,
Handbook of coding theory, 1998. ,
The theory of Error Correcting Codes (North-Holland Mathematical Library). Amsterdam, The Netherlands, 1977. ,
On q-ary plateaued functions over F q and their explicit characterizations functions, European Journal of Combinatorics ,
, S-Boxes and Round Functions with Controllable Linearity and Differential Uniformity. In Fast Software Encryption-FSE'94 (Lecture Notes in Computer Science), vol.1008, pp.111-130, 1995.
New explicit constructions of differentially 4uniform permutations via special partitions of F 2 2k. Finite Fields and Their Applications, vol.40, pp.73-89, 2016. ,
On the maximum number of bent component of vectorial functions, IEEE Trans. Information Theory, vol.64, issue.1, pp.403-411, 2018. ,
On a conjecture of differentially 8uniform power functions, Des. Codes Cryptography, vol.86, issue.8, pp.1601-1621, 2018. ,
Plateaued functions, Information and Communication Security, ICICS'99, vol.1726, pp.284-300, 1999. ,
