Harnessing clusters of hybrid nodes with a sequential task-based programming model, 8th International Workshop on Parallel Matrix Algorithms and Applications, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01283949
StarPU: A Unified Platform for Task Scheduling on Heterogeneous Multicore Architectures, Concurrency and Computation: Practice and Experience, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00384363
Legion: Expressing locality and independence with logical regions, International Conf. on High Performance Computing, Networking, Storage and Analysis, 2012. ,
The PEPPHER approach to programmability and performance portability for heterogeneous many-core architectures, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00661320
Scaling gysela code beyond 32k-cores on Blue Gene/Q, ESAIM: PROCEEDINGS, volume CEMRACS 2012 of 43, pp.117-135, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01050322
An approach to increase reliability of hpc simulation, application to the GYSELA5D Code, ESAIM: Proceedings and Surveys, number 53 in CEMRACS 2014-Numerical Modeling of Plasmas, pp.191-210, 2014. ,
URL : https://hal.archives-ouvertes.fr/cea-01305504
Productive programming of gpu clusters with ompss, International Parallel and Distributed Processing Symposium, 2012. ,
A multiprocessor system design, Fall Joint Computer Conference, AFIPS'63, pp.139-146, 1963. ,
, Ludovic Courtès. C Language Extensions for Hybrid CPU/GPU Programming with StarPU, INRIA, 2013.
A parallel Vlasov solver based on local cubic spline interpolation on patches, Journal of Computational Physics, vol.228, pp.1429-1446, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00771580
XKaapi: A Runtime System for DataFlow Task Programming on Heterogeneous Architectures, International Symposium on Parallel and Distributed Processing, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00799904
A 5d gyrokinetic full-global semi-lagrangian code for flux-driven ion turbulence simulations, Computer Physics Communications, vol.207, pp.35-68, 2016. ,
URL : https://hal.archives-ouvertes.fr/cea-01153011
Gyrokinetic Semi-Lagrangian parallel simulation using a hybrid OpenMP/MPI programming, Recent Advances in Parallel Virtual Machine and Message Passing Interface, vol.4757, pp.356-364, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00605748
, OpenMP Architecture Review Board. OpenMP Application Programming Interface Version, vol.4, issue.5, 2015.
Controlling the Memory Subscription of Distributed Applications with a Task-Based Runtime System, 21st International Workshop on High-Level Parallel Programming Models and Supportive Environments, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01284004
The Semi-Lagrangian method for the numerical resolution of the Vlasov equation, Journal of Computational Physics, vol.149, issue.2, pp.201-220, 1999. ,
, , pp.2015-2027
BOAST: Bringing Optimization through Automatic Source-toSource Tranformations, Proceedings of the 7th International Symposium on Embedded Multicore/Manycore System-on-Chip (MCSoC), 2013. ,
BOAST: a Metaprogramming Framework to Produce Portable and Efficient Computing Kernels for HPC Applications. The International Journal of High Performance Computing Applications, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01620778
Hierarchical dag scheduling for hybrid distributed systems, International Parallel and Distributed Processing Symposium, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01078359
, dim => [Dim(-DECNR,ALLOCSIZER-DECNR-1),Dim(NTHETA),Dim(NPHI)
, type_name => "geom_t
, dim =>
