Incremental Learning for Semantic Segmentation of Large-Scale Remote Sensing Data
Onur Tasar 1 Yuliya Tarabalka 1 Pierre Alliez 1
1 TITANE - Geometric Modeling of 3D Environments
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : In spite of remarkable success of the convolutional neural networks on semantic segmentation, they suffer from catastrophic forgetting: a significant performance drop for the already learned classes when new classes are added on the data, having no annotations for the old classes. We propose an incre-mental learning methodology, enabling to learn segmenting new classes without hindering dense labeling abilities for the previous classes, although the entire previous data are not accessible. The key points of the proposed approach are adapting the network to learn new as well as old classes on the new training data, and allowing it to remember the previously learned information for the old classes. For adaptation, we keep a frozen copy of the previously trained network, which is used as a memory for the updated network in absence of annotations for the former classes. The updated network minimizes a loss function, which balances the discrepancy between outputs for the previous classes from the memory and updated networks, and the mis-classification rate between outputs for the new classes from the updated network and the new ground-truth. For remembering, we either regularly feed samples from the stored, little fraction of the previous data or use the memory network, depending on whether the new data are collected from completely different geographic areas or from the same city. Our experimental results prove that it is possible to add new classes to the network, while maintaining its performance for the previous classes, despite the whole previous training data are not available.
Complete list of metadatas
Cited literature [50 references]  Display  Hide  Download
https://hal.inria.fr/hal-01909830
Contributor : Onur Tasar <>
Submitted on : Wednesday, November 27, 2019 - 10:34:38 AM
Last modification on : Thursday, November 28, 2019 - 1:28:11 AM
File
incremental_learning.pdf
Identifiers
Collections
Citation
Onur Tasar, Yuliya Tarabalka, Pierre Alliez. Incremental Learning for Semantic Segmentation of Large-Scale Remote Sensing Data. IEEE Journal of Selected Topics in Applied Earth Observations and Remote Sensing, IEEE, 2019, 12 (9), pp.3524-3537. ⟨10.1109/JSTARS.2019.2925416⟩. ⟨hal-01909830v2⟩
Share
Metrics
Record views
43
Files downloads
136
