Abstract : Despite the recent successes of deep reinforcement learning, teaching complex motor skills to a physical robot remains a hard problem. While learning directly on a real system is usually impractical, doing so in simulation has proven to be fast and safe. Nevertheless, because of the "reality gap," policies trained in simulation often perform poorly when deployed on a real system. In this work, we introduce a method for training a recurrent neural network on the differences between simulated and real robot trajectories and then using this model to augment the simulator. This Neural-Augmented Simulation (NAS) can be used to learn control policies that transfer significantly better to real environments than policies learned on existing simulators. We demonstrate the potential of our approach through a set of experiments on the Mujoco simulator with added backlash and the Poppy Ergo Jr robot. NAS allows us to learn policies that are competitive with ones that would have been learned directly on the real robot.
https://hal.inria.fr/hal-01911978 Contributor : Florian GolemoConnect in order to contact the contributor Submitted on : Monday, November 5, 2018 - 5:37:37 AM Last modification on : Saturday, June 25, 2022 - 9:11:56 PM Long-term archiving on: : Wednesday, February 6, 2019 - 1:35:58 PM
