A Closed-Form Solution of Rotation Invariant Spherical Harmonic Features in Diffusion MRI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Rotation invariant features are an indispensable tool for characterizing diffusion Magnetic Resonance Imaging (MRI) and in particular for brain tissue microstructure estimation. In this work, we propose a new mathematical framework for efficiently calculating a complete set of such invariants from any spherical function. Specifically, our method is based on the spherical harmonics series expansion of a given function of any order and can be applied directly to the resulting coefficients by performing a simple integral operation analytically. This enable us to derive a general closed-form equation for the invariants. We test our invariants on the diffusion MRI fiber orientation distribution function obtained from the diffusion signal both in-vivo and in synthetic data. Results show how it is possible to use these invariants for characterizing the white matter using a small but complete set of features.
rif_cdmri.pdf (771.71 Ko) Télécharger le fichier
hal-01912148 , version 1 (05-11-2018)
  • HAL Id : hal-01912148 , version 1
Mauro Zucchelli, Samuel Deslauriers-Gauthier, Rachid Deriche. A Closed-Form Solution of Rotation Invariant Spherical Harmonic Features in Diffusion MRI. MICCAI - Computational Diffusion MRI Workshop 2018, Sep 2018, Granada, Spain. ⟨hal-01912148⟩
192 Consultations
651 Téléchargements
