"Fingers in the Nose": Evaluating Speakers' Identification of Multi-Word Expressions Using a Slightly Gamified Crowdsourcing Platform
This article presents the results we obtained in crowdsourcing French speakers' intuition concerning multi-work expressions (MWEs). We developed a slightly gamified crowdsourcing platform, part of which is designed to test users' ability to identify MWEs with no prior training. The participants perform relatively well at the task, with a recall reaching 65% for MWEs that do not behave as function words.
Traitement du texte et du document
