A theory of reversibility for Erlang - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Logical and Algebraic Methods in Programming Année : 2018
In a reversible language, any forward computation can be undone by a finite sequence of backward steps. Reversible computing has been studied in the context of different programming languages and formalisms, where it has been used for testing and verification, among others. In this paper, we consider a subset of Erlang, a functional and concurrent programming language based on the actor model. We present a formal semantics for reversible computation in this language and prove its main properties, including its causal consistency. We also build on top of it a rollback operator that can be used to undo the actions of a process up to a given checkpoint.
paper.pdf (571.39 Ko) Télécharger le fichier
hal-01912856 , version 1 (06-11-2018)
Ivan Lanese, Naoki Nishida, Adrian Palacios, Germán Vidal. A theory of reversibility for Erlang. Journal of Logical and Algebraic Methods in Programming, 2018, 100, pp.71 - 97. ⟨10.1016/j.jlamp.2018.06.004⟩. ⟨hal-01912856⟩
78 Consultations
108 Téléchargements
