New interface
Conference papers
Learning to program in a constructionist way
Mattia Monga 1 Michael Lodi 2 Dario Malchiodi 1 Anna Morpurgo 1 Bernadette Spieler 3
2 FOCUS - Foundations of Component-based Ubiquitous Systems
CRISAM - Inria Sophia Antipolis - Méditerranée , DISI - Dipartimento di Informatica - Scienza e Ingegneria [Bologna]
Abstract : Although programming is often seen as a key element of constructionist approaches, the research on learning to program through a constructionist strategy is somewhat limited, mostly focusing on how to bring the abstract and formal nature of programming languages into "concrete" or even tangible objects, graspable even by children with limited abstraction power. However, in order to enable constructionism in programming several challenges must be addressed. One of the crucial difficulties for novice programmers is to understand the complex relationship between the program itself (the text of the code) and the actions that take place when the program is run by the interpreter. A good command of the notional machine is a necessary condition to build programming skills, as is recognizing how a relatively low number of abstract patterns can be applied to a potentially infinite spectrum of specific situations. Programming languages and environments can either help or distract novices, thus the choice is not neutral and their characteristics should be analyzed carefully to foster a good learning context. The mastery of the notional machine, however, is just the beginning of the game: to develop a real competence one must be able to think about problems in a way suitable to automatic elaboration; to devise, analyse, and compare solutions, being able to adapt them to unexpected hurdles and needs. Moreover, it is important to learn to work productively in a team, in an "organized" way: agile methods seem based on common philosophical grounds with constructionism.
Document type :
Conference papers
Complete list of metadata
Cited literature [75 references]  Display  Hide  Download
https://hal.inria.fr/hal-01913065
Contributor : Michael Lodi Connect in order to contact the contributor
Submitted on : Tuesday, November 6, 2018 - 12:58:27 AM
Last modification on : Tuesday, November 22, 2022 - 5:32:24 PM
Long-term archiving on: : Thursday, February 7, 2019 - 12:40:03 PM
File
wg-programming.pdf
Identifiers
  • HAL Id : hal-01913065, version 1
Collections
Citation
Mattia Monga, Michael Lodi, Dario Malchiodi, Anna Morpurgo, Bernadette Spieler. Learning to program in a constructionist way. Proceedings of Constructionism 2018, Aug 2018, Vilnius, Lithuania. ⟨hal-01913065⟩
Share
Metrics
Record views
103
Files downloads
786
