Terrain Partitioning Based Approach for Realistic Deployment of Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Mustapha Reda Senouci
  • Fonction : Auteur
  • PersonId : 1038434
Mohamed Aissani
  • Fonction : Auteur
  • PersonId : 1038435
This paper addresses the NP-hard problem of deploying wireless sensor networks on 3D terrains. On the contrary to previous works that place the sensors without any analysis of the terrain, we propose a two-phase solution based on terrain partitioning. The main idea is to estimate the number of sensors to be used and simplify the sensors deployment by partitioning the terrain according to topographic criteria. Simulation results based on real-world terrains confirm the efficiency of our solution in terms of coverage quality.
467079_1_En_37_Chapter.pdf (3.15 Mo) Télécharger le fichier
hal-01913882 , version 1 (06-11-2018)
Paternité
Mostefa Zafer, Mustapha Reda Senouci, Mohamed Aissani. Terrain Partitioning Based Approach for Realistic Deployment of Wireless Sensor Networks. 6th IFIP International Conference on Computational Intelligence and Its Applications (CIIA), May 2018, Oran, Algeria. pp.423-435, ⟨10.1007/978-3-319-89743-1_37⟩. ⟨hal-01913882⟩
103 Consultations
65 Téléchargements
