Conference papers
Evolutionary Multi-objective Optimization of Business Process Designs with MA-NSGAII
Abstract : Optimization is known as the process of finding the best possible solution to a problem given a set of constraints. The problem becomes challenging when dealing with conflicting objectives, which leads to a multiplicity of solutions. Evolutionary algorithms, which use a population approach in their search procedures, are advised to suitably solve the problem. In this article, we present an approach for an evolutionary combinatorial multi-objective optimization of business process designs using a variation of NSGAII, baptized MA-NSGAII. The variants of NSGAII are numerous. In fact, the vast majority deals either with the crossover operator or with the crowding distance. We discuss an optimization Framework that uses (i) a proposal of effective Fitness function, (ii) 02 contradictory criteria to optimize and (iii) an original selection technique. We test the proposed Framework with a real life case of multi-objective optimization of business process designs. The obtained results clearly indicate that an effectual Fitness function combined with the appropriate selection operator affects undeniably quality and quantity of solutions.
Document type :
Conference papers
Complete list of metadata
Cited literature [29 references]  Display  Hide  Download
https://hal.inria.fr/hal-01913899
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Wednesday, November 7, 2018 - 10:12:26 AM
Last modification on : Thursday, November 8, 2018 - 1:27:07 PM
Long-term archiving on: : Friday, February 8, 2019 - 12:43:28 PM
File
467079_1_En_30_Chapter.pdf
Identifiers
Citation
Nadir Mahammed, Sidi Mohamed Benslimane, Nesrine Hamdani. Evolutionary Multi-objective Optimization of Business Process Designs with MA-NSGAII. 6th IFIP International Conference on Computational Intelligence and Its Applications (CIIA), May 2018, Oran, Algeria. pp.341-351, ⟨10.1007/978-3-319-89743-1_30⟩. ⟨hal-01913899⟩
Share
Metrics
Record views
33
Files downloads
65
