Quality-of-service routing for supporting multimedia applications. Selected Areas in Communications, IEEE Journal on, vol.14, issue.7, pp.1228-1234, 1996. ,
Multicast routing based on genetic algorithms, J. Inf. Sci. Eng, vol.16, issue.6, pp.885-901, 2000. ,
GA-based heuristic algorithms for QoS based multicast routing. Knowledge-Based Systems, vol.16, pp.305-312, 2003. ,
QoS-driven multicast tree generation using tabu search, Computer Communications, vol.25, issue.11, pp.1140-1149, 2002. ,
A path relinking approach for delay-constrained least-cost multicast routing problem, 19th IEEE International Conference on, vol.1, pp.383-390, 2007. ,
QoS multicast routing based on particle swarm optimization, Intelligent Data Engineering and Automated LearningIDEAL, pp.936-943, 2006. ,
Particle swarm optimization for the Steiner tree in graph and delay-constrained multicast routing problems, Journal of Heuristics, vol.19, issue.2, pp.317-342, 2013. ,
Using bio-inspired approaches to improve the quality of service in a multicast routing, International Journal of Communication Networks and Distributed Systems, vol.19, issue.2, pp.186-213, 2017. ,
An Improved Chaotic Binary Bat Algorithm for QoS Multicast Routing, International Journal on Artificial Intelligence Tools, vol.25, issue.04, p.1650025, 2016. ,
QoS multicast routing using a quantumbehaved particle swarm optimization algorithm, Engineering Applications of Artificial Intelligence, vol.24, issue.1, pp.123-131, 2011. ,
An improved discrete PSO with GA operators for efficient QoS-multicast routing, International Journal of Hybrid Information Technology, vol.4, issue.2, pp.23-38, 2011. ,
Animal migration optimization: an optimization algorithm inspired by animal migration behavior, Neural Computing and Applications, vol.24, issue.7-8, pp.1867-1877, 2014. ,
Logistic chaotic maps for binary numbers generations, Chaos, Solitons & Fractals, vol.40, issue.5, pp.2557-2568, 2009. ,
Differential evolution optimization combined with chaotic sequences for image contrast enhancement, Chaos, Solitons & Fractals, vol.42, issue.1, pp.522-529, 2009. ,
Routing of multipoint connections. Selected Areas in Communications, IEEE Journal on, vol.6, issue.9, pp.1617-1622, 1988. ,
