Abdelfatah Nasri The Efficiency of Direct Torque Control for Electric Vehicle Behavior Improvement SERBIAN, JOURNAL OF ELECTRICAL ENGINEERING, vol.8, issue.2, pp.127-146, 2011. ,
Abdellah Laoufi and Youssef Mouloudi ,4 WD Urban Electric Vehicle Motion Studies Based on MIMO Fuzzy Logic Speed Controller, Faculty of the sciences and technology, Bechar University International Journal of Control and Automation, vol.6, issue.1, 2013. ,
Commande direct du couple dun vehicule electrique deux roues motrices, vol.47, p.99, 2012. ,
Cleaning the air with fuel cell vehicles : net impact on emissions and energy use of replacing conventional internal combustion engine vehicles with hydrogen fuel cell vehicles, The First European Fuel Cell Technology and Applications Conference, 2005. ,
Proton exchange membrane fuel cell system model for automotive vehicle simulation and control, ASME Journal of Energy Resources Technology, 2002. ,
Fuel Cell Handbook, 2004. ,
Simulation of fuel-cell stacks using a computer-controlled power rectifier with the purposes of actual high-power injection applications, IEEE Transactions on Industry Applications, issue.4, p.39, 2003. ,
Efficiency-Optimized Variable Structure Direct Torque Control for Synchronous Reluctance Motor Drives Electrical Systems, vol.8, pp.95-107, 2012. ,
Novel Direct Torque Control Based on Space Vector Modulation With Adaptive Stator Flux Observer for Induction, IEEE TRANSACTIONS ON MAGNETICS, vol.46, issue.8, 2010. ,
Improvement in DTC-SVM of AC Drives Using a New Robust Adaptive Control Algorithm, International Journal of Control Automation and System, IJCAS, vol.9, issue.2, 2011. ,
Study of Energy Management Schemes for a FuelCell Hybrid Emergency Power System of More-Electric Aircraft Souleman Njoya Motapon, Member, IEEE, IEEE TRANSACTIONS ON INDUSTRIAL ELECTRONICS, vol.61, issue.3, 2014. ,
On-line fuzzy energy management for hybrid fuel cell systems, Int. J. Hydrogen Energy, vol.35, issue.5, p.21342143, 2010. ,
