A taxonomy of global optimization methods based on response surfaces, Journal of Global Optimization, vol.21, pp.345-383, 2001. ,
Spectral methods for uncertainty quantification, 2010. ,
The wiener-askey polynomial chaos for stochastic differential equations, SIAM J Sci Comput, vol.24, issue.2, pp.619-644, 2002. ,
A polynomial dimensional decomposition for stochastic computing, International Journal for Numerical Methods in Engineering, vol.76, pp.2191-2116, 2008. ,
Radial Basis Functions, 2003. ,
Statistics for spatial data, 1993. ,
Aerodynamic shape optimization of civil structures: A CFDenabled Kriging-based approach, Journal of Wind Engineering and Industrial Aerodynamics, vol.144, pp.154-164, 2015. ,
Sensitivity estimates for nonlinear mathematical models, Mathematical modelling & Computational Experiments, vol.1, pp.407-414, 1993. ,
Global sensitivity indices for nonlinear mathematical models and their Monte Carlo estimates, Mathematics and Computers in Simulations, vol.55, pp.271-280, 2001. ,
Adaptive-sparse polynomial dimensional decomposition methods for high-dimensional stochastic computing, Comput. Methods Appl. Mech. Engrg, vol.274, pp.56-83, 2014. ,
DOI : 10.1016/j.cma.2014.01.027
URL : http://arxiv.org/pdf/1402.3330
A comparison of three methods for selecting values of input variables in the analysis of output from a computer code, Technometrics, vol.21, issue.2, pp.239-245, 1979. ,
DACE: a MATLAB kriging toolbox, version 2.0, 2002. ,
Optimal latin-hypercube designs for computer experiments, J. Stat. Plan. Inference, vol.39, pp.95-111, 1994. ,
DOI : 10.1016/0378-3758(94)90115-5
Adaptive response surface method using inherited latin hypercube design points, Journal of Mechanical Design, vol.125, pp.210-220, 2003. ,
DOI : 10.1115/1.1561044
URL : http://www.sfu.ca/%7Egwa5/index_files/Jmd-arsm.PDF
Design and analysis of computer experiments, Statistical sciences, vol.4, issue.4, pp.409-435, 1989. ,
Efficient global optimization of expensive black-box functions, Journal of Global Optimization, vol.13, pp.455-492, 1998. ,
An adaptive stochastic finite elements approach based on newton-cotes quadrature in simplex elements, Computers & Fluids, vol.38, pp.1270-1288, 2009. ,
Refinement criteria for simplex stochastic collocation with local extremum diminishing robustness ,
, SIAM J. Sci. Comput, vol.34, issue.3, pp.1522-1543, 2012.
Simplex stochastic collocation with random sampling and extrapolation for nonhypercube probability spaces, SIAM J. Sci. Comput, vol.34, issue.2, pp.814-838, 2012. ,
Simplex stochastic collocation with ENO-type stencil selection for robust uncertainty quantification, Journal of Computational Physics, vol.239, pp.1-21, 2013. ,
Metric construction by length distribution tensor and edge based error for anisotropic adaptive meshing, Journal of Computational Physics, vol.230, pp.2391-2405, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00579536
Adaptive time-step with anisotropic meshing for incompressible flows, Journal of Computational Physics, vol.241, pp.195-211, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01470576
Mesh adaptive direct search algorithms for constrained optimization, SIAM Journal on Optimization, vol.17, issue.1, pp.188-217, 2006. ,
Introduction to Derivative-Free Optimization, Society for Industrial and Applied Mathematics, 2009. ,
A radial basis function method for global optimization, Journal of Global Optimization, vol.19, issue.3, pp.201-227, 2001. ,
A stochastic radial basis function method for the global optimization of expensive functions, INFORMS Journal on Computing, vol.19, issue.4, pp.497-509, 2007. ,
Stochastic radial basis function algorithms for largescale optimization involving expensive black-box objective and constraint functions, Comput. Oper. Res, vol.38, issue.5, pp.837-853, 2011. ,
A method for simulation based optimization using radial basis functions, Optimization and Engineering, vol.11, issue.4, pp.501-532, 2010. ,
An adaptive algorithm to build up sparse polynomial chaos expansions for stochastic finite element analysis. Probabilistic Engineering Mechanics, vol.25, pp.183-197, 2010. ,
Efficient computation of global sensitivity indices using sparse polynomial chaos expansions, Reliability Engineering & System Safety, vol.95, issue.11, pp.1216-1229, 2010. ,
Adaptive anova decomposition of stochastic incompressible and compressible flows, Journal of Computational Physics, vol.231, issue.4, pp.1587-1614, 2012. ,
Anchor points matter in anova decomposition ,
, Spectral and High Order Methods for Partial Differential Equations, pp.347-355, 2011.
An adaptive high-dimensional stochastic model representation technique for the solution of stochastic partial differential equations, Journal of Computational Physics, vol.229, issue.10, pp.3884-3915, 2010. ,
Valuation of mortgage-backed securities using brownian bridges to reduce the effective dimension, Journal of Computational Finance, vol.1, pp.27-46, 1997. ,
The theory of regionalised variables and its applications, 1971. ,
Improving accuracy and compensating for uncertainty in surrogate modeling, 2009. ,
URL : https://hal.archives-ouvertes.fr/tel-00770844
Comparing error estimation measures for polynomial and kriging approximation of noise-free functions. Structural and multidisciplinary optimization, vol.38, pp.429-442, 2009. ,
Active subspace method in theory and practice: application to kriging surfaces, SIAM J. Sci. Comput, vol.36, issue.4, pp.1500-1524, 2014. ,
A hybrid anchored-ANOVAPOD/kriging method for uncertainty quantification in unsteady highfidelity CFD simulations, Journal of Computational Physics, vol.324, pp.137-173, 2016. ,
Monte carlo implementation of gaussian process models for bayesian regression and classification, 1997. ,
Designs for computer experiments, Technometrics, vol.31, issue.1, pp.41-47, 1989. ,
Space-Time accurate anisotropic adaptation and stabilized finite element methods for the resolution of unsteady CFD problems. Theses, 2014. ,
URL : https://hal.archives-ouvertes.fr/tel-01146245
A feed-back approach to error control in finite element methods: Basic analysis and examples, East-West J. Numer. Math, vol.4, pp.237-264, 1996. ,
URL : https://hal.archives-ouvertes.fr/inria-00343044
Stabilised hp-finite element approximation of partial differential equations with nonnegative characteristic form, Computing, vol.66, issue.2, pp.99-119, 2001. ,
An optimal control approach to a posteriori error estimation in finite element methods, Acta Numerica, vol.10, pp.1-102, 2001. ,
Adjoint methods for pdes: a posteriori error analysis and postprocessing by duality, Acta Numerica, vol.11, pp.145-236, 2002. ,
A class of discontinuous petrov-galerkin methods, Adaptivity. Applied Numerical Mathematics, vol.62, issue.4, pp.396-427, 2012. ,
A General Lagrangian Formulation for the Computation of A Posteriori Finite Element Bounds, pp.159-206 ,
A posteriori error estimates for optimal control problems, 14th IFAC Workshop on Control Applications of Optimization, vol.42, pp.85-90, 2009. ,
Multitarget error estimation and adaptivity in aerodynamic flow simulations, SIAM Journal on Scientific Computing, vol.31, issue.1, pp.708-731, 2008. ,
A new goaloriented formulation of the finite element method, Computer Methods in Applied Mechanics and Engineering, vol.327, pp.256-276, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01633411
Worst-case multiobjective error estimation and adaptivity, Computer Methods in Applied Mechanics and Engineering, vol.313, pp.723-743, 2017. ,
A partition-of-unity dual-weighted residual approach for multi-objective goal functional error estimation applied to elliptic problems, vol.17, p.2017 ,
Computationally inexpensive metamodel assessment strategies, AIAA Journal, vol.40, issue.10, pp.2053-2060, 2002. ,
A comparative study between kriging and adaptive sparse tensorproduct methods for multi-dimensional approximation problems in aerodynamics design, ESAIM: PROCEEDINGS AND SURVEYS, vol.48, pp.248-261, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01353245
On the efficiency of certain quasi-random sequences of points in evaluating multi-dimensional integrals, Numerische Mathematik, vol.2, pp.84-90, 1960. ,
Bayesian-based method with metamodels for rebuilding freestream conditions in atmospheric entry flows, AIAA Journal, vol.52, issue.10, pp.2190-2197, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00855898
Accurate and efficient modelling of high temperature nonequilibrium air flows, 2001. ,
Chemical-kinetic parameters of hyperbolic earth entry, Journal of Thermophysics and Heat Transfer, vol.15, issue.1, pp.76-90, 2001. ,
Towards the ultimate conservative difference scheme. V. A second-order sequel to godunov's method, Journal of Computational Physics, vol.32, issue.1, pp.101-136, 1979. ,
, Upwind Difference Schemes for Hyperbolic Systems of Conservation Laws. Mathematics of Computation, vol.38, pp.339-374, 1982.
The VKI Plasmatron Characteristics and Performance. Defense Technical Information Center, 2000. ,
Porous-material analysis toolbox based on openfoam and applications, Journal of Thermophysics and Heat Transfer, vol.28, issue.2, pp.191-202, 2014. ,
