Topological analysis of representations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Computable analysis is the theoretical study of the abilities of algorithms to process infinite objects. The algorithms abilities depend on the way these objects are presented to them. We survey recent results on the problem of identifying the properties of objects that are decidable or semidecidable, for several concrete classes of objects and representations of them. Topology is at the core of this study, as the decidable and semidecidable properties are closely related to the open sets induced by the representation.
final.pdf (244.13 Ko) Télécharger le fichier
hal-01919395 , version 1 (12-11-2018)
  • HAL Id : hal-01919395 , version 1
Mathieu Hoyrup. Topological analysis of representations. CiE 2018 - Fourteenth conference on Computability in Europe, Jul 2018, Kiel, Germany. ⟨hal-01919395⟩
65 Consultations
157 Téléchargements
