Coding for QUIC", Work in Progress, NWCRG draft-swett-nwcrg-codingfor-quic, 2018. ,
QUIC: A UDP-Based Multiplexed and Secure Transport, 2018. ,
Key words for use in RFCs to Indicate Requirement Levels, BCP, vol.14, p.2119, 1997. ,
, , 2018.
Sliding Window Random Linear Code (RLC) Forward Erasure Correction (FEC) Scheme for FECFRAME, Work in Progress, 2018. ,
, 2. Informative References
Taxonomy of Coding Techniques for Efficient Network Communications", draft-irtf-nwcrgnetwork-coding-taxonomy (Work in Progress) (work in progress), 2018. ,
