Gapped blast and psi-blast: a new generation of protein database search programs, Nucleic Acids Research, vol.25, issue.17, pp.3389-3402, 1997. ,
Bladyg: A graph processing framework for large dynamic graphs, Big Data Research, vol.9, pp.9-17, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01577882
Pseudo amino acid composition and its applications in bioinformatics, proteomics and system biology, Current Proteomics, vol.6, issue.4, pp.262-274, 2009. ,
DOI : 10.2174/157016409789973707
Exploiting indirect neighbours and topological weight to predict protein function from protein-protein interactions, Bioinformatics, vol.22, issue.13, pp.1623-1630, 2006. ,
DOI : 10.1007/11691730_1
URL : https://link.springer.com/content/pdf/10.1007%2F11691730_1.pdf
Uniprot: a hub for protein information, Nucleic Acids Research, vol.43, pp.204-212, 2015. ,
Current iubmb recommendations on enzyme nomenclature and kinetics, Perspectives in Science, vol.1, issue.1-6, pp.74-87, 2014. ,
DOI : 10.1016/j.pisc.2014.02.006
URL : https://hal.archives-ouvertes.fr/hal-01494614
Mapreduce: simplified data processing on large clusters, Communications of the ACM, vol.51, issue.1, pp.107-113, 2008. ,
Predicting enzyme class from protein structure without alignments, Journal of molecular biology, vol.345, issue.1, pp.187-199, 2005. ,
DOI : 10.1016/j.jmb.2004.10.024
URL : http://cbio.ensmp.fr/~jvert/svn/bibli/local/Dobson2005Predicting.pdf
Hmmer web server: interactive sequence similarity searching, Nucleic Acids Research, vol.39, issue.2, pp.29-37, 2011. ,
DOI : 10.1093/nar/gkr367
URL : https://academic.oup.com/nar/article-pdf/39/suppl_2/W29/7628106/gkr367.pdf
Automated annotation of microbial proteomes in SWISS-PROT, Computational Biology and Chemistry, vol.27, issue.1, pp.49-58, 2003. ,
Assessment of prediction accuracy of protein function from protein-protein interaction data, Yeast, vol.18, issue.6, pp.523-531, 2001. ,
Accurate prediction of enzyme subfamily class using an adaptive fuzzy k-nearest neighbor method, Biosystems, vol.90, issue.2, pp.405-413, 2007. ,
Prediction of enzyme classification from protein sequence without the use of sequence similarity, Proc Int Conf Intell Syst Mol Biol, vol.5, pp.92-99, 1997. ,
Interproscan 5: genome-scale protein function classification, Bioinformatics, vol.30, issue.9, pp.1236-1240, 2014. ,
DOI : 10.1093/bioinformatics/btu031
URL : https://academic.oup.com/bioinformatics/article-pdf/30/9/1236/653449/btu031.pdf
Automatic rule generation for protein annotation with the c4.5 data mining algorithm applied on swiss-prot, Bioinformatics, vol.17, pp.920-926, 2001. ,
Eficaz2. 5: application of a high-precision enzyme function predictor to 396 proteomes, Bioinformatics, vol.28, issue.20, pp.2687-2688, 2012. ,
Protein domain organisation: adding order, BMC Bioinformatics, vol.10, issue.1, p.39, 2009. ,
DOI : 10.1186/1471-2105-10-39
URL : https://bmcbioinformatics.biomedcentral.com/track/pdf/10.1186/1471-2105-10-39
Deepre: sequence-based enzyme ec number prediction by deep learning, Bioinformatics, vol.34, issue.5, pp.760-769, 2018. ,
Svm-prot 2016: a web-server for machine learning prediction of protein functional families from sequence irrespective of similarity, PloS one, vol.11, issue.8, 2016. ,
Ecs: an automatic enzyme classifier based on functional domain composition, Computational biology and chemistry, vol.31, issue.3, pp.226-232, 2007. ,
Whole-proteome prediction of protein function via graph-theoretic analysis of interaction maps, Bioinformatics, vol.21, issue.1, pp.302-310, 2005. ,
Prediction of detailed enzyme functions and identification of specificity determining residues by random forests, PloS one, vol.9, issue.1, 2014. ,
Efficiency analysis of knn and minimum distance-based classifiers in enzyme family prediction, Computational biology and chemistry, vol.33, issue.6, pp.461-464, 2009. ,
Enzymedetector: an integrated enzyme function prediction tool and database, BMC bioinformatics, vol.12, issue.1, p.376, 2011. ,
DOI : 10.1186/1471-2105-12-376
URL : https://bmcbioinformatics.biomedcentral.com/track/pdf/10.1186/1471-2105-12-376
Interproscan: protein domains identifier, Nucleic acids research, vol.33, issue.2, pp.116-120, 2005. ,
DOI : 10.1093/nar/gki442
URL : https://academic.oup.com/nar/article-pdf/33/suppl_2/W116/7623230/gki442.pdf
Ec-blast: a tool to automatically search and compare enzyme reactions, Nature methods, vol.11, issue.2, p.171, 2014. ,
A network of protein-protein interactions in yeast, Nature biotechnology, vol.18, issue.12, p.1257, 2000. ,
Ezypred: a top-down approach for predicting enzyme functional classes and subclasses, Biochemical and biophysical research communications, vol.364, issue.1, pp.53-59, 2007. ,
Accurate prediction of protein enzymatic class by n-to-1 neural networks, BMC bioinformatics, vol.14, issue.1, p.11, 2013. ,
The i-tasser suite: protein structure and function prediction, Nature methods, vol.12, issue.1, p.7, 2015. ,
Genome-wide enzyme annotation with precision control: Catalytic families (catfam) databases, Proteins: Structure, Function, and Bioinformatics, vol.74, issue.2, pp.449-460, 2009. ,
DOI : 10.1002/prot.22167
Apache spark: a unified engine for big data processing, Communications of the ACM, vol.59, issue.11, pp.56-65, 2016. ,
Cofactor: improved protein function prediction by combining structure, sequence and protein-protein interaction information, Nucleic Acids Research, vol.45, issue.1, pp.291-299, 2017. ,
DOI : 10.1093/nar/gkx366
URL : https://academic.oup.com/nar/article-pdf/45/W1/W291/23741003/gkx366.pdf
An efficient method for protein function annotation based on multilayer protein networks, Human genomics, vol.10, issue.1, p.33, 2016. ,
DOI : 10.1186/s40246-016-0087-x
URL : https://humgenomics.biomedcentral.com/track/pdf/10.1186/s40246-016-0087-x
