Unifying Speech and Computation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Martin John Wheatman
  • Fonction : Auteur
  • PersonId : 1023549
A novel approach to programming computing machinery is demonstrated by the EnguageTM language engine: programming by utterance. The running of a command is modeled as a deductive process; the mechanism by which meaning is ascribed to utterance—induction—is described. A full example of the factorial function is given. The paper then develops utterance not only as a form of issuing commands to hardware, but also of storing, retrieving, and manipulating spoken information—a programmable UI. Because such utterances can be generated by speech-to-text software, such interactive computation does not require a program as a written artifact.
470225_1_En_17_Chapter.pdf (255.93 Ko) Télécharger le fichier
hal-01920730 , version 1 (13-11-2018)
Paternité
Martin John Wheatman. Unifying Speech and Computation. 18th International Conference on Informatics and Semiotics in Organisations (ICISO), Jul 2018, Reading, United Kingdom. pp.167-176, ⟨10.1007/978-3-319-94541-5_17⟩. ⟨hal-01920730⟩
52 Consultations
53 Téléchargements
