A Framework to Support the Design of Digital Initiatives in Social Science Based Research - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Stuart Moran
  • Fonction : Auteur
  • PersonId : 1011667
Sophie Berckhan
  • Fonction : Auteur
  • PersonId : 1038838
Alison Clarke
  • Fonction : Auteur
  • PersonId : 1038839
The rapid development of new digital technologies has increased the expectations of academic research outputs. To meet these pressures, researchers have greater expectations of their digital work environments. In this paper we outline the drivers for digital transformation at our institution and how this manifested itself in a series of exploratory projects called digital initiatives. Based on our findings we propose a Digital Research Initiative framework to support research institutions in assessing and implementing digital transformation.
470225_1_En_18_Chapter.pdf (341.51 Ko) Télécharger le fichier
hal-01920735 , version 1 (13-11-2018)
Paternité
Stuart Moran, Sophie Berckhan, Alison Clarke. A Framework to Support the Design of Digital Initiatives in Social Science Based Research. 18th International Conference on Informatics and Semiotics in Organisations (ICISO), Jul 2018, Reading, United Kingdom. pp.177-186, ⟨10.1007/978-3-319-94541-5_18⟩. ⟨hal-01920735⟩
54 Consultations
71 Téléchargements
