Spectrum-efficient and scalable elastic optical path network: architecture, benefits, and enabling technologies, IEEE Communications Magazine, vol.47, issue.11, 2009. ,
Distance-adaptive spectrum resource allocation in spectrum-sliced elastic optical path network, IEEE Communications Magazine, vol.48, issue.8, 2010. ,
Routing and spectrum assignment in spectrum sliced elastic optical path network, IEEE Communications Letters, vol.15, issue.8, pp.884-886, 2011. ,
California fault lines: understanding the causes and impact of network failures, ACM SIGCOMM Computer Communication Review, 2010. ,
Analysis of link failures in an ip backbone, Proceedings of the 2nd ACM SIGCOMM Workshop on Internet measurment, 2002. ,
Survivable wdm mesh networks, Journal of Lightwave Technology, vol.21, issue.4, 2003. ,
Fault management in ip-over-wdm networks: Wdm protection versus ip restoration, IEEE journal on selected areas in communications, vol.20, issue.1, 2002. ,
Survivability in optical networks, IEEE network, vol.14, issue.6, pp.16-23, 2000. ,
Offline rsa algorithms for elastic optical networks with dedicated path protection consideration, Ultra Modern Telecommunications and Control Systems and Workshops (ICUMT), 2012 4th International Congress on, 2012. ,
An evolutionary algorithm approach for dedicated path protection problem in elastic optical networks, Cybernetics and Systems, vol.44, issue.6-7, pp.589-605, 2013. ,
, A genetic algorithm for solving rsa problem in elastic optical networks with dedicated path protection, International Joint Conference CISIS12-ICEUTE´12ICEUTE´12-SOCO´12SOCO´12 Special Sessions, pp.167-176, 2013.
Optimal design for shared backup path protected elastic optical networks under single-link failure, Journal of Optical Communications and Networking, vol.6, issue.7, 2014. ,
Shared backup path protection in elastic optical networks: Modeling and optimization, Design of Reliable Communication Networks (DRCN), 2013 9th International Conference on the, pp.187-194, 2013. ,
Column generation algorithm for rsa problems in flexgrid optical networks, Photonic network communications, vol.26, issue.2-3, 2013. ,
Elastic bandwidth allocation in flexible ofdm-based optical networks, Journal of Lightwave Technology, vol.29, issue.9, pp.1354-1366, 2011. ,
Reach-dependent capacity in optical networks enabled by ofdm, Proc. Optical Fiber Communication, 2009. ,
Planning and operating flexible optical networks: Algorithmic issues and tools, IEEE Communications Magazine, vol.52, issue.1, 2014. ,
, Linear Programming, 1983.
, Computers and intractability. wh freeman New York, vol.29, 2002.
Shortest path problems with resource constraints, pp.33-65, 2005. ,
Sndlib 1.0survivable network design library, Networks, vol.55, issue.3, 2010. ,
Optical WDM networks, 2006. ,
Dynamic service provisioning in elastic optical networks with hybrid single-/multi-path routing, Journal of Lightwave Technology, vol.31, issue.1, pp.15-22, 2013. ,
Increasing the robustness of ip backbones in the absence of optical level protection, INFOCOM 2003, pp.1-11, 2003. ,
