A consumer tracking estimator for vehicles in GPS-free environments, IEEE Trans. Consum. Electron, vol.63, issue.4, pp.450-458, 2017. ,
Design, implementation, and experimental results of a quaternion-based Kalman filter for human body motion tracking, IEEE Trans. Robot, vol.22, issue.6, pp.1216-1227, 2006. ,
Performance comparison of EKF-based algorithms for orientation estimation on android platform, IEEE Sensors J, vol.15, issue.7, pp.3781-3792, 2015. ,
Integrated navigation system for a low-cost quadrotor aerial vehicle in the presence of rotor influences, J. Surv. Eng, vol.143, issue.1, 2017. ,
3D stroke reconstruction and cursive script recognition with magnetometer-aided inertial measurement unit, IEEE Trans. Consum. Electron, vol.58, issue.2, pp.661-669, 2012. ,
Effective adaptive Kalman filter for MEMSIMU/magnetometers integrated attitude and heading reference systems, J. Navig, vol.66, issue.1, pp.99-113, 2012. ,
Magnetic sensors for navigation applications: An overview, J. Navig, vol.67, issue.2, pp.263-275, 2014. ,
Fast linear quaternion attitude estimator using vector observations, IEEE Trans. Autom. Sci. Eng, vol.15, issue.1, pp.307-319, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01513263
A simplified quaternionbased algorithm for orientation estimation from earth gravity and magnetic field measurements, IEEE Trans. Instrum. Meas, vol.57, issue.3, pp.638-650, 2008. ,
Fast quaternion attitude estimation from two vector measurements, J. Guid. Control Dyn, vol.25, issue.2, pp.411-414, 2002. ,
A linear Kalman filter for MARG orientation estimation using the algebraic quaternion algorithm, IEEE Trans. Instrum. Meas, vol.65, issue.2, pp.467-481, 2016. ,
Analytic accelerometermagnetometer attitude determination without reference information, Int. J. Micro Air Veh, 2018. ,
UAV state estimation using adaptive complementary filters, IEEE Trans. Control Syst. Technol, vol.24, issue.4, pp.1214-1226, 2016. ,
Complementary observer for body segments motion capturing by inertial and magnetic sensors, IEEE/ASME Trans. Mechatronics, vol.19, issue.1, pp.149-157, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00690145
Modified unscented quaternion estimator based on quaternion averaging, J. Guid. Control Dyn, vol.37, issue.1, pp.305-308, 2014. ,
Kalman-filtering-based in-motion coarse alignment for odometer-aided SINS, IEEE Trans. Instrum. Meas, vol.66, issue.12, pp.3364-3377, 2017. ,
Equality constrained robust measurement fusion for adaptive Kalman-filter-based heterogeneous multisensor navigation, IEEE Trans. Aerosp. Electron. Syst, vol.49, issue.4, pp.2146-2157, 2013. ,
Orientation estimation in mobile virtual environments with inertial sensors, IEEE Trans. Consum. Electron, vol.57, issue.2, pp.802-810, 2011. ,
Energy-aware adaptive attitude estimation under external acceleration for pedestrian navigation, IEEE/ASME Trans. Mechatronics, vol.21, issue.3, pp.1366-1375, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01241403
Attitude determination using a single sensor observation: Analytic quaternion solutions and property discussion, IET Sci. Meas. Technol, vol.11, issue.3, pp.731-739, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01514132
Estimation of IMU and MARG orientation using a gradient descent algorithm, Proc. IEEE Int. Conf. Rehabil. Robot, pp.1-7, 2011. ,
Steepest descent quaternion attitude estimator, Aerosp. Sci. Technol, vol.77, pp.1-10, 2018. ,
An adaptive-gain complementary filter for real-time human motion tracking with MARG sensors in free-living environments, IEEE Trans. Neural Syst. Rehabil. Eng, vol.21, issue.2, pp.254-264, 2013. ,
A nonlinear filtering approach for the attitude and dynamic body acceleration estimation based on inertial and magnetic sensors: Bio-logging application, IEEE Sensors J, vol.11, issue.1, pp.233-244, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00624142
, Fundamentals of Spacecraft Attitude Determination and Control, vol.2, 2014.
An analytic solution to Wahba's problem, Aerosp. Sci. Technol, vol.30, issue.1, pp.46-49, 2013. ,
Fast complementary filter for attitude estimation using low-cost MARG sensors, IEEE Sensors J, vol.16, issue.18, pp.6997-7007, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01368473
Three-axis attitude determination from vector observations, J. Guid. Control Dyn, vol.4, issue.1, pp.70-77, 1981. ,
The Definitive Guide to ARM Cortex-M3 and Cortex-M4 Processors, 2013. ,
Applying features of IEEE 754 to sign/logarithm arithmetic, IEEE Trans. Comput, vol.41, issue.8, pp.1040-1050, 1992. ,
The ARM RISC Chip: A Programmer's Guide, 1994. ,
Using and Porting the GNU Compiler Collection, 2009. ,
Round-Robin scheduling for max-min fairness in data networks, IEEE J. Sel. Areas Commun, vol.9, issue.7, pp.1024-1039, 1991. ,
Accelerating seismic computations using customized number representations on FPGAs, EURASIP J. Embedded Syst, issue.1, 2008. ,
