A Probabilistic Model for Joint Learning of Word Embeddings from Texts and Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Several recent studies have shown the benefits of combining language and perception to infer word embeddings. These multimodal approaches either simply combine pre-trained textual and visual representations (e.g. features extracted from convolutional neural networks), or use the latter to bias the learning of textual word embeddings. In this work, we propose a novel probabilistic model to formalize how linguistic and perceptual inputs can work in concert to explain the observed word-context pairs in a text corpus. Our approach learns textual and visual representations jointly: latent visual factors couple together a skip-gram model for co-occurrence in linguistic data and a generative latent variable model for visual data. Extensive experimental studies validate the proposed model. Concretely, on the tasks of assessing pairwise word similarity and image/caption retrieval, our approach attains equally competitive or stronger results when compared to other state-of-the-art multimodal models.
emnlp18.pdf (372.59 Ko) Télécharger le fichier
hal-01922985 , version 1 (14-11-2018)
  • HAL Id : hal-01922985 , version 1
Melissa Ailem, Bowen Zhang, Aurélien Bellet, Pascal Denis, Fei Sha. A Probabilistic Model for Joint Learning of Word Embeddings from Texts and Images. Conference on Empirical Methods in Natural Language Processing (EMNLP 2018), 2018, Brussels, Belgium. ⟨hal-01922985⟩
110 Consultations
199 Téléchargements
