Incremental delay enumeration: Space and time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Applied Mathematics Année : 2018
We investigate the relationship between several enumeration complexity classes andfocus in particular on problems having enumeration algorithms with incremental andpolynomial delay ( IncP andDelayP respectively). We show that, for some algorithms, wecan turn an average delay into a worst case delay without increasing the space complexity,suggesting that IncP1 = DelayP even with polynomially bounded space. We use theExponential Time Hypothesis to exhibit a strict hierarchy inside IncP which gives the firstseparation of DelayP andIncP. Finally we relate the uniform generation of solutions toprobabilistic enumeration algorithms with polynomial delay and polynomial space.
S0166218X18304001.pdf (412.08 Ko) Télécharger le fichier
hal-01923091 , version 1 (21-12-2021)
Paternité - Pas d'utilisation commerciale
Florent Capelli, Yann Strozecki. Incremental delay enumeration: Space and time. Discrete Applied Mathematics, 2018, ⟨10.1016/j.dam.2018.06.038⟩. ⟨hal-01923091⟩
125 Consultations
78 Téléchargements
