Learning natural coding conventions, Proceedings of the 22Nd ACM SIGSOFT International Symposium on Foundations of Software Engineering, FSE 2014, pp.281-293, 2014. ,
An industrial evaluation of unit test generation: Finding real faults in a financial application, 2017 IEEE/ACM 39th International Conference on Software Engineering: Software Engineering in Practice Track (ICSE-SEIP), pp.263-272, 2017. ,
A novel co-evolutionary approach to automatic software bug fixing, Evolutionary Computation, pp.162-168, 2008. ,
DSpot: Test Amplification for Automatic Assessment of Computational Diversity, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01162219
From genetic to bacteriological algorithms for mutation-based testing. Software, Testing, Verification & Reliability journal (STVR), vol.15, pp.73-96, 2005. ,
Test-driven development: by example, 2003. ,
Travistorrent: Synthesizing travis ci and github for full-stack research on continuous integration, Proceedings of the 14th working conference on mining software repositories, 2017. ,
, The emerging field of test amplification: A survey, 2017.
URL : https://hal.archives-ouvertes.fr/hal-01634288
Hints on test data selection: Help for the practicing programmer, Computer, vol.11, issue.4, pp.34-41, 1978. ,
Five misunderstandings about case-study research, Qualitative inquiry, vol.12, issue.2, pp.219-245, 2006. ,
The seed is strong: Seeding strategies in search-based software testing, Software Testing, Verification and Validation, pp.121-130, 2012. ,
Whole test suite generation, IEEE Transactions on Software Engineering, vol.39, issue.2, pp.276-291, 2013. ,
Achieving scalable mutation-based generation of whole test suites, Empirical Software Engineering, vol.20, issue.3, pp.783-812, 2014. ,
Does automated unit test generation really help software testers? a controlled empirical study, ACM Transactions on Software Engineering and Methodology (TOSEM), vol.24, issue.4, p.23, 2015. ,
Dart: directed automated random testing, ACM Sigplan Notices, vol.40, pp.213-223, 2005. ,
Randomized differential testing as a prelude to formal verification, Proceedings of the 29th international conference on Software Engineering, pp.621-631, 2007. ,
An approach to test data generation for killing multiple mutants, 22nd IEEE International Conference on Software Maintenance, pp.113-122, 2006. ,
Improving test suites via operational abstraction, Proc. of the Int. Conf. on Software Engineering (ICSE), pp.60-71, 2003. ,
Leveraging existing tests in automated test generation for web applications, Proceedings of the 29th ACM/IEEE international conference on Automated software engineering, pp.67-78, 2014. ,
Spoon: A library for implementing analyses and transformations of java source code, Software: Practice and Experience, vol.46, pp.1155-1179, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01078532
Genetic improvement of software: a comprehensive survey, IEEE Transactions, 2017. ,
Generating effective integration test cases from unit ones, Proceedings of the 2013 IEEE Sixth International Conference on Software Testing, Verification and Validation, ICST '13, pp.11-20, 2013. ,
Isolating failure causes through test case generation, Proceedings of the 2012 International Symposium on Software Testing and Analysis, pp.309-319, 2012. ,
Adopting devops practices in quality assurance, Commun. ACM, vol.56, 2013. ,
Evolutionary testing of classes, Proceedings of the 2004 ACM SIGSOFT International Symposium on Software Testing and Analysis, ISSTA '04, pp.119-128, 2004. ,
Coevolutionary automated software correction, Proceedings of the 12th annual conference on Genetic and evolutionary computation, pp.1391-1392, 2010. ,
Augmenting Automatically Generated Unit-test Suites with Regression Oracle Checking, Proceedings of the 20th European Conference on Object-Oriented Programming, pp.380-403, 2006. ,
Augmenting automatically generated unit-test suites with regression oracle checking, ECOOP 2006-Object-Oriented Programming, pp.380-403, 2006. ,
Test case purification for improving fault localization, Proceedings of the 22Nd ACM SIGSOFT International Symposium on Foundations of Software Engineering, FSE 2014, pp.52-63, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01061911
Crash Reproduction via Test Case Mutation: Let Existing Test Cases Help, Proceedings of the 2015 10th Joint Meeting on Foundations of Software Engineering, ESEC/FSE 2015, pp.910-913, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01172102
Test data regeneration: Generating new test data from existing test data, Softw. Test. Verif. Reliab, vol.22, issue.3, pp.171-201, 2012. ,
Mutation-oriented Test Data Augmentation for GUI Software Fault Localization, Inf. Softw. Technol, vol.55, issue.12, pp.2076-2098, 2013. ,
Isomorphic regression testing: Executing uncovered branches without test augmentation, Proceedings of the 2016 24th ACM SIGSOFT International Symposium on Foundations of Software Engineering, FSE 2016, pp.883-894, 2016. ,
