Towards the modelling of the Purkinje/ myocardium coupled problem: A well-posedness analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2019
The Purkinje network is the specialized conduction system in the heart. It ensures the physiological spread of the electrical wave in the ventricles. In this work, in an insulated heart framework, we model the free running Purkinje system, using the monodomain equation. The intra-myocardium part of the Purkinje fiber is coupled to the ventricular tissue using the bidomain equation. The coupling is performed through the extracellular potential. We discretize the problem in time using a semi-implicit scheme. Then, we write a variational formulation of the semi discrete problem in a non standard weighted Sobolev functional spaces. We prove the existence and uniqueness of the solution of the Purkinje/myocardium semi-discretized problem. We discretize in space by the finite element P 1 − Lagrange and conduct some numerical tests showing the anterograde and retrograde propagation of the electrical wave between the tissue and the Purkinje fibers.
monodomainbidomain.pdf (835.12 Ko) Télécharger le fichier
hal-01923779 , version 1 (15-11-2018)
Saloua Mani Aouadi, Wajih Mbarki, Nejib Zemzemi. Towards the modelling of the Purkinje/ myocardium coupled problem: A well-posedness analysis. Journal of Computational and Applied Mathematics, 2019, ⟨10.1016/j.cam.2018.10.024⟩. ⟨hal-01923779⟩
92 Consultations
223 Téléchargements
