Boundary data completion: the method of boundary value problem factorization, Inverse Problems, vol.27, issue.5, p.55014, 2011. ,
Missing boundary data reconstruction via an approximate optimal control, Inverse Problems & Imaging, vol.2, issue.4, pp.411-426, 2008. ,
A control type method for solving the cauchy-stokes problem, Applied mathematical modelling, vol.37, issue.6, pp.4295-4304, 2013. ,
Stochastic finite element method for torso conductivity uncertainties quantification in electrocardiography inverse problem, Mathematical Modelling of Natural Phenomena, vol.11, issue.2, pp.1-19, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01289144
Data completion via an energy error functional, Comptes Rendus Mécanique, vol.333, issue.2, pp.171-177, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00086964
On cauchy's problem: Ii. completion, regularization and approximation, Inverse problems, vol.22, issue.4, p.1307, 2006. ,
Relating epicardial to body surface potential distributions by means of transfer coefficients based on geometry measurements, Biomedical Engineering, pp.1-11, 1977. ,
Accuracy of lead removal vs linear interpolation in non-invasive electrocardiographic imaging (ecgi), Computing in Cardiology Conference (CinC), 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01241752
Dynamic programming and the variation of Green's functions. RAND Corporation, 1957. ,
Inverse problem in electrocardiography via factorization method of boundary problems: how reconstruct epicardial potential maps from measurements of the torso?, International Symposium on Biomedical Imaging (ISBI), 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00926344
A field-compatible method for interpolating biopotentials, Annals of biomedical engineering, vol.26, issue.1, pp.37-47, 1998. ,
Convergence analysis for finite element approximation to an inverse cauchy problem, Inverse Problems, vol.22, issue.4, p.1191, 2006. ,
Methods of solving reduced lead systems for inverse electrocardiography, Biomedical Engineering, vol.54, issue.2, pp.339-343, 2007. ,
Lectures on Cauchy's problem in linear partial differential equations, Courier Corporation, 2014. ,
Misfit functional for recovering data in 2d electrocardiography problems, Engineering Analysis with Boundary Elements, vol.34, issue.5, pp.492-500, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00489550
Factorization of second-order elliptic boundary value problems by dynamic programming, Nonlinear Analysis: Theory, Methods & Applications, vol.59, pp.629-647, 2004. ,
Study of the initial value problems appearing in a method of factorization of second-order elliptic boundary value problems, Nonlinear Analysis: Theory, Methods & Applications, vol.68, pp.2984-3008, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00402387
La méthode de factorisation des problèmes aux limites par plongement invariant, 2016. ,
Complétion de données frontieres: la méthode de plongement invariant, 2012. ,
An iterative method for solving the cauchy problem for elliptic equations, Zhurnal Vychislitel'noi Matematiki i Matematicheskoi Fiziki, vol.31, issue.1, pp.64-74, 1991. ,
Problemes aux limites non homogenes et applications. Dunod, 1968. ,
Regularization methods for ill-posed problems, 1993. ,
Interpolation on a triangulated 3d surface, Journal of Computational Physics, vol.80, issue.2, pp.331-343, 1989. ,
Solutions of ill-posed problems, 1977. ,
Application of the method of fundamental solutions to potential-based inverse electrocardiography, Annals of biomedical engineering, vol.34, issue.8, pp.1272-1288, 2006. ,
A steklov-poincaré variational formulation of the inverse problem in cardiac electrophysiology, CinCComputing in Cardiology Conference, p.193, 2013. ,
An iterative method for solving the inverse problem in electrocardiography imaging: From body surface to heart potential, Computing in Cardiology Conference (CinC), pp.717-720, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01065107
