Kallel, missing boundary data reconstruction via an approximate optimal control, Inverse Problems and Imaging, vol.2, issue.4, pp.411-426, 2008. ,
Stochastic finite element method for torso conductivity uncertainties quantification in electrocardiography inverse problem, Mathematical Modelling of Natural Phenomena, vol.11, issue.2, pp.1-19, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01289144
Solving cauchy problems by minimizing an energy-like functional, Inverse problems, vol.22, issue.1, pp.115-133, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00139569
Stochastic inverse heat conduction using a spectral approach, Int. J. Numer. Meth. Engng, vol.60, issue.7, pp.1-24, 2004. ,
Galerkin finite element approximations of stochastic elliptic partial differential equations, SIAM Journal on Numerical Analysis, vol.42, issue.2, pp.800-825, 2005. ,
Solving elliptic boundary value problems with uncertain coefficients by the finite element method: the stochastic formulation, Comput. Methods Appl. Mech. Engrg, vol.194, pp.1251-1294, 2005. ,
The inverse problem in electrocardiography: A model study of the effects of geometry and conductivity parameters on the reconstruction of epicardial potentials, IEEE transactions on biomedical engineering, vol.33, issue.7, pp.667-676, 1986. ,
, Eléments finis stochastiques: approches intrusive et non intrusive pour des analyses de fiabilité, 2005.
Mathematical modeling of electrocardiograms: a numerical study, Annals of biomedical engineering, vol.38, issue.3, pp.1071-1097, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00400490
Monte carlo sensitivity analysis of input-output models, The Review of Economics and Statistics, vol.70, issue.1, pp.708-712, 1988. ,
An efficient Monte Carlo method for optimal control problems with uncertainty, Computational Optimization and Applications, vol.26, issue.2, pp.219-230, 2003. ,
Numerical solutions for optimal control problems under SPDE constraints, 2006. ,
Bayesian state and parameter estimation of uncertain dynamical systems, Elsevier Probabilistic Engineering Mechanics, vol.21, issue.1, pp.81-96, 2006. ,
Physical Properties of Tissue: A Comprehensive Reference Book, 1990. ,
Computational aspects of the stochastic finite element method Computing and Visualization in, Science, issue.1, pp.3-15, 2007. ,
The electric resistivity of human tissues (100 hz-10 mhz): a meta-analysis of review studies, Physiological measurement, issue.4, pp.1-11, 1999. ,
Decoupled time-marching schemes in computational cardiac electrophysiology and ecg numerical simulation, Mathematical biosciences, vol.226, issue.1, pp.58-75, 2010. ,
The dielectric properties of biological tissues: Ii. measurements in the frequency range 10 hz to 20 ghz, Physics in medicine and biology, vol.41, issue.11, pp.22-51, 1996. ,
Application of stochastic finite element methods to study the sensitivity of ecg forward modeling to organ conductivity, Biomedical Engineering, vol.55, issue.1, pp.31-40, 2008. ,
The forward and inverse problems of electrocardiography, EMBS Magazine, vol.17, issue.5, pp.84-101, 1998. ,
Lectures on Cauchy's problem in linear partial differential equations, 1923. ,
A review of techniques for parameter sensitivity analysis of environmental models, The Review of Economics and Statistics, vol.32, issue.2, pp.135-154, 1994. ,
On using perturbation analysis to do sensitivity analysis: derivatives versus differences, IEEE Transactions on Automatic Control, vol.37, issue.2, pp.243-247, 1992. ,
Finite element approximations of stochastic optimal control problems constrained by stochastic elliptic pdes, Elsevier Journal of Mathematical Analysis and Applications, vol.384, pp.87-103, 2011. ,
A stochastic projection method for fluid flow: II. random process, Elsevier Journal of Computational Physics, vol.181, issue.1, pp.9-44, 2002. ,
On elliptic partial differential equations with random coefficients, Babes-Bolyai Math, vol.56, issue.2, pp.473-487, 2011. ,
The effect of torso inhomogeneities on body surface potentials quantified using tailored geometry, Journal of electrocardiology, vol.22, issue.1, pp.53-72, 1989. ,
Electrocardiographic imaging: II. Effect of torso inhomogeneities on noninvasive reconstruction of epicardial potentials, electrograms and isochrones, Journal of cardiovascular electrophysiology, vol.12, issue.2, pp.241-252, 2001. ,
Optimal control with stochastic PDE constraints and uncertain controls, Computer Methods in Applied Mechanics and Engineering, vol.213, pp.152-167, 2012. ,
Stochastic collocation for optimal control problems with stochastic PDE constraints, SIAM J. Control optim, vol.50, issue.5, pp.2659-2682, 2012. ,
Parameter sensitivity and uncertainty of the forest carbon flux model forug: a Monte Carlo analysis, Tree Physiology, vol.26, issue.1, pp.807-817, 2006. ,
A Bayesian approach to multiscale inverse problems using the sequential Monte Carlo method, Inverse Problems, vol.27, issue.10, pp.105004-105029, 2011. ,
Predicting tissue conductivity influences on body surface potentialsan efficient approach based on principal component analysis, Biomedical Engineering IEEE Transactions, vol.58, issue.2, pp.256-273, 2011. ,
The homogeneous chaos, Am. J. Math, vol.60, pp.897-936, 1938. ,
Modeling uncertainty in flow simulations via generalized polynomial chaos, J.Comput.Phys, vol.187, issue.1, pp.137-167, 2003. ,
A scalable framework for the solution of stochastic inverse problems using a sparse grid collocation approach, Elsevier Journal of Computational Physics, vol.227, issue.9, pp.4697-4735, 2008. ,
