Mixed Integer Linear Programming for Feature Selection in Support Vector Machine - Archive ouverte HAL Access content directly
Journal Articles Discrete Applied Mathematics Year : 2019
(1) , (2) , (2)
1
2
This work focuses on support vector machine (SVM) with feature selection. A MILP formulation is proposed for the problem. The choice of suitable features to construct the separating hyperplanes has been modelled in this formulation by including a budget constraint that sets in advance a limit on the number of features to be used in the classification process. We propose both an exact and a heuristic procedure to solve this formulation in an efficient way. Finally, the validation of the model is done by checking it with some well-known data sets and comparing it with classical classification methods.
mainFS_SVM_no_color.pdfmainFS_SVM_no_color[1].pdf (3.55 Mo) Télécharger le fichier
Dates and versions
hal-01924379 , version 1 (15-11-2018)
Identifiers
Cite
Martine Labbé, Luisa Isabel Martínez-Merino, Antonio Manuel Rodríguez-Chía. Mixed Integer Linear Programming for Feature Selection in Support Vector Machine. Discrete Applied Mathematics, 2019, 261, pp.276-304. ⟨10.1016/j.dam.2018.10.025⟩. ⟨hal-01924379⟩
68 View
268 Download
Share
