New interface
Conference papers
A sensor fusion approach for inertial sensors based 3D kinematics and pathological gait assessments: toward an adaptive control of stimulation in post-stroke subjects
Abstract : Pathological gait assessment and assistive control based on functional electrical stimulation (FES) in post-stroke individuals, brings out a common need to robustly quantify kinematics facing multiple constraints. This study proposes a novel approach using inertial sensors to compute dorsiflexion angles and spatio-temporal parameters, in order to be later used as inputs for online close-loop control of FES. 26 post-stroke subjects were asked to walk on a pressure mat equipped with inertial measurement units (IMU) and passive reflective markers. A total of 930 strides were individually analyzed and results between IMU-based algorithms and reference systems compared. Mean absolute (MA) errors of dorsiflexion angles were found to be less than 4°, while stride lengths were robustly segmented and estimated with a MA error less than 10 cm. These results open new doors to rehabilitation using adaptive FES closed-loop control strategies in "foot drop" syndrome correction.
Document type :
Conference papers
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01924841
Contributor : Benoît Sijobert Connect in order to contact the contributor
Submitted on : Friday, November 16, 2018 - 4:26:49 PM
Last modification on : Friday, August 5, 2022 - 10:53:05 AM
Long-term archiving on: : Sunday, February 17, 2019 - 1:39:00 PM
File
Article EMBC - VERSION SOUMISE...
Identifiers
Collections
Citation
Benoît Sijobert, François Feuvrier, Jérôme Froger, David Guiraud, Christine Azevedo Coste. A sensor fusion approach for inertial sensors based 3D kinematics and pathological gait assessments: toward an adaptive control of stimulation in post-stroke subjects. EMBC: Engineering in Medicine and Biology Conference, Jul 2018, Honolulu, United States. pp.3497-3500, ⟨10.1109/EMBC.2018.8512985⟩. ⟨hal-01924841⟩
Share
Metrics
Record views
125
Files downloads
440
