Strengthened Formulations and Valid Inequalities for Single Delay Management in Public Transportation
The Delay Management Problem arises in Public Transportation networks, often characterized by the necessity of connections between different vehicles. The attractiveness of Public Transportation networks is strongly related to the reliability of connections, which can be missed when delays or other unpredictable events occur. Given a single initial delay at one node of the network, the Delay Management Problem is to determine which vehicles have to wait for the delayed ones, with the aim of minimizing the dissatisfaction of the passengers. In this paper, we present strengthened mixed integer linear programming formulations and new families of valid inequalities. The implementation of branch-and-cut methods and tests on a benchmark of instances taken from real networks show the potential of the proposed formulations and cuts.
