Verifying Safety of Synchronous Fault-Tolerant Algorithms by Bounded Model Checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Owing to well-known limitations of what can be achieved in purely asynchronous systems, many fault-tolerant distributed algorithms are designed for synchronous or round-based semantics. In this paper, we introduce the synchronous variant of threshold automata, and study their applicability and limitations for the verification of synchronous distributed algorithms. We show that in general, the reachability problem is undecidable for synchronous threshold automata. Still, we show that many synchronous fault-tolerant distributed algorithms have a bounded diameter, although the algorithms are parameterized by the number of processes. Hence, we use bounded model checking for verifying these algorithms. The existence of bounded diameters is the main conceptual insight in this paper. We compute the diameter of several algorithms and check their safety properties, using SMT queries that contain quantifiers for dealing with the parameters symbolically. Surprisingly, performance of the SMT solvers on these queries is very good, reflecting the recent progress in dealing with quantified queries. We found that the diameter bounds of synchronous algorithms in the literature are tiny (from 1 to 4), which makes our approach applicable in practice. For a specific class of algorithms we also establish a theoretical result on the existence of a diameter , providing a first explanation for our experimental results.
syncTAs.pdf (430.64 Ko) Télécharger le fichier
hal-01925653 , version 1 (16-11-2018)
hal-01925653 , version 2 (11-10-2019)
  • HAL Id : hal-01925653 , version 1
Ilina Stoilkovska, Igor Konnov, Josef Widder, Florian Zuleger. Verifying Safety of Synchronous Fault-Tolerant Algorithms by Bounded Model Checking. 2018. ⟨hal-01925653v1⟩
376 Consultations
296 Téléchargements
