metaBEETL: high-throughput analysis of heterogeneous microbial populations from shotgun DNA sequences, BMC Bioinf, vol.14, issue.5, p.2, 2013. ,
Lightweight algorithms for constructing and inverting the BWT of string collections, Theoret. Comput. Sci, vol.483, issue.0, pp.134-148, 2013. ,
Efficient Bubble Enumeration in Directed Graphs, SPIRE, vol.7608, pp.118-129, 2012. ,
A Block Sorting data Compression Algorithm, 1994. ,
Lightweight LCP construction for very large collections of strings, J. Discrete Algorithms, vol.37, pp.17-33, 2016. ,
Comparing DNA sequence collections by direct comparison of compressed text indexes, WABI, LNBI 7534, pp.214-224, 2012. ,
Using reference-free compressed data structures to analyze sequencing reads from thousands of human genomes, Gen. Res, vol.27, issue.2, pp.300-309, 2017. ,
Lightweight BWT and LCP merging via the Gap algorithm, SPIRE, vol.10508, pp.176-190, 2017. ,
Assemblathon 1: A competitive assessment of de novo short read assembly methods, Gen. Res, vol.21, issue.12, pp.2224-2241, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00637571
Opportunistic data structures with applications, FOCS, pp.390-398, 2000. ,
When Whole-Genome Alignments Just Won't Work: kSNP v2 Software for Alignment-Free SNP Discovery and Phylogenetics of Hundreds of Microbial Genomes, PLoS ONE, vol.8, issue.12, p.81760, 2013. ,
De novo assembly and genotyping of variants using colored de Bruijn graphs, Nature Genetics, vol.44, issue.2, pp.226-232, 2012. ,
Analysis of genomic rearrangements by using the BurrowsWheeler transform of short-read data, BMC Bioinf, vol.16, p.5, 2015. ,
Ultrafast SNP analysis using the Burrows-Wheeler transform of short-read data, Bioinformatics, vol.31, issue.10, pp.1577-1583, 2015. ,
Indexing arbitrary-length k-mers in sequencing reads, PLoS ONE, vol.10, issue.7, 2015. ,
Fast gapped-read alignment with Bowtie 2, Nat. Methods, vol.9, issue.4, pp.357-359, 2012. ,
Reference-free SNP detection: dealing with the data deluge, 12 Detecting Mutations by eBWT, vol.15, p.10, 2014. ,
Identifying and Classifying Trait Linked Polymorphisms in Non-Reference Species by Walking Coloured de Bruijn Graphs, PLoS ONE, vol.8, issue.3, pp.1-11, 2013. ,
Mapping-free and assembly-free discovery of inversion breakpoints from raw NGS reads, AlCoB, pp.119-130, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01063157
Fast and accurate short read alignment with Burrows-Wheeler transform, Bioinformatics, vol.25, issue.14, pp.1754-1760, 2009. ,
SOAP2: an improved ultrafast tool for short read alignment, Bioinformatics, vol.25, issue.15, pp.1966-1967, 2009. ,
SOAPindel: efficient identification of indels from short paired reads, Gen. Res, vol.23, issue.1, pp.195-200, 2013. ,
Toward perfect reads: self-correction of short reads via mapping on de Bruijn graphs, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01644163
Inducing enhanced suffix arrays for string collections, Theor. Comput. Sci, vol.678, pp.22-39, 2017. ,
Generalized enhanced suffix array construction in external memory, Algorithms for Molecular Biology, vol.12, issue.1, p.26, 2017. ,
Suffix arrays: a new method for on-line string searches, SODA, pp.319-327, 1990. ,
An extension of the Burrows-Wheeler Transform, Theoret. Comput. Sci, vol.387, issue.3, pp.298-312, 2007. ,
DiscoSnp++: de novo detection of small variants from raw unassembled read set(s). bioRxiv, 2017. ,
Identifying SNPs without a Reference Genome by comparing raw reads, SPIRE, vol.6393, pp.147-158, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00514887
Querying large read collections in main memory: a versatile data structure, BMC Bioinf, vol.12, p.242, 2011. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00632958
KISSPLICE: de-novo calling alternative splicing events from RNA-seq data, BMC Bioinf, vol.13, issue.S-6, p.5, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00784407
LoRDEC: accurate and efficient long read error correction, Bioinformatics, vol.30, issue.24, pp.3506-3514, 2014. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01100451
Accurate self-correction of errors in long reads using de Bruijn graphs, Bioinformatics, vol.33, issue.6, pp.799-806, 2017. ,
URL : https://hal.archives-ouvertes.fr/lirmm-01385006
Illumina error profiles: resolving fine-scale variation in metagenomic sequencing data, BMC Bioinf, vol.17, issue.1, p.125, 2016. ,
Suffix Arrays for Multiple Strings: A Method for On-Line Multiple String Searches, ASIAN, pp.11-22, 1996. ,
, The 1000 Genomes Project Consortium. A global reference for human genetic variation, Nature, vol.526, pp.68-74, 2015.
Reference-free detection of isolated SNPs, Nuc.Acids Res, vol.43, issue.2, p.11, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01083715
Scalable and Versatile k-mer Indexing for High-Throughput Sequencing Data, ISBRA, vol.7875, pp.237-248, 2013. ,
