Exact solutions to a class of stochastic generalized assignment problems, Eur J Oper Res, vol.173, pp.465-487, 2006. ,
A two-stage model for a day-ahead paratransit planning problem, Math Methods Oper Res, vol.69, pp.323-341, 2009. ,
Integrated chance constraints: reduced forms and an algorithm, Comput Manag Sci, vol.3, pp.245-269, 2006. ,
On the convex hull of the simple integer recourse objective function, Ann Oper Res, vol.56, pp.209-224, 1995. ,
An algorithm for the construction of the convex hull of the simple integer recourse objective function, Ann Oper Res, vol.64, pp.67-81, 1996. ,
Simple integer recourse models: convexity and convex approximations, Math Program, vol.108, pp.435-473, 2006. ,
Collective adjustment of pension rights in ALM models, Comput Manag Sci, vol.8, pp.137-156, 2011. ,
Stochastic programming with simple integer recourse, Math Program, vol.61, pp.301-325, 1993. ,
Modeling farmers' response to uncertain rainfall in Burkina Faso: a stochastic programming approach, Oper Res, vol.50, pp.399-414, 2002. ,
Convex approximations for totally unimodular integer recourse models: a uniform error bound, SIAM J Optim, vol.25, pp.130-158, 2015. ,
A convex approximation for two-stage mixed-integer recourse models with a uniform error bound, SIAM J Optim, vol.26, pp.426-447, 2016. ,
Total variation bounds on the expectation of periodic functions with applications to recourse approximations, Math Program, vol.157, pp.3-46, 2016. ,
Assessing the quality of convex approximations for two-stage totally unimodular integer recourse models, INFORMS J Comput, vol.29, pp.211-231, 2017. ,
Solving stochastic integer programs by enumeration: a framework using Gröbner basis reductions, Math Program, vol.83, pp.229-252, 1998. ,
Modelling aspects of distributed processing in telecommunication networks, Ann Oper Res, vol.82, pp.161-184, 1998. ,
Stochastic programming with integer recourse, Thesis Rijksuniversiteit Groningen, Theses on Systems, Organisations, and Management. Labyrint Publications, Capelle a/d Ijssel van der Vlerk MH (2004) Convex approximations for complete integer recourse models, Math Program, vol.99, pp.297-310, 1995. ,
Convex approximations for a class of mixed-integer recourse models, Ann Oper Res, vol.177, pp.139-150, 2010. ,
