Measurable sub-Riemannian geometry on the lifted Sierpinski gasket to the Heisenberg group - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
We construct a lift of the Sierpinski gasket to the Heisenberg group, the invariant set of a horizontal iterated functions system. As we have a post critically finite self-similar set, using analytic approach, we define a local regular Dirichlet form. By using the theory of Dirichlet forms, we have a diffusion process and a Laplacian which we have defines as being the limit of discrete Laplacians on a sequence of finite graphs which approximate this set.
article_sierpinski_horizontal.pdf (554.23 Ko) Télécharger le fichier
hal-01927134 , version 1 (19-11-2018)
  • HAL Id : hal-01927134 , version 1
Samia Haraketi, Ezedine Haouala, Antoine Lejay. Measurable sub-Riemannian geometry on the lifted Sierpinski gasket to the Heisenberg group. 2018. ⟨hal-01927134⟩
178 Consultations
108 Téléchargements
