Adaptive generation of quasi-optimal tetrahedral meshes, East-West Journal, vol.7, issue.4, pp.223-244, 1999. ,
High order sonic boom modeling by adaptive methods, J. Comp. Phys, vol.229, pp.561-593, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00363206
Adaptive anisotropic simulations in aerodynamics, 48th AIAA Aerospace Sciences Meeting and Exhibit, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00935369
Anisotropic unstructured mesh adaptation for flow simulations, Int. J. Num. Meth. in Fluids, vol.25, pp.475-491, 1997. ,
Anisotropic mesh adaptation: towards a solver and user independent CFD, AIAA 35th Aerospace Sciences Meeting and Exhibit, 1997. ,
Error bounds for controllable adaptive algorithms based on a hessian recovery, Computational Mathematics and Mathematical Physics, vol.45, issue.8, pp.1374-1384, 2005. ,
Metric tensors for anisotropic mesh generation, J. Comp. Phys, vol.204, pp.633-665, 2005. ,
Anisotropic mesh adaptation for CFD computations, Comp. Meth. Applied Mech. Eng, vol.194, pp.5068-5082, 2005. ,
Continuous mesh framework. Part I: well-posed continuous interpolation error, vol.49, pp.38-60, 2011. ,
Continuous mesh framework. Part II: validations and applications, SIAM Num. Anal, vol.49, issue.1, pp.61-86, 2011. ,
Anisotropic Norm-Oriented Mesh Adaptation for Compressible Flows, 53rd AIAA Aerospace Sciences Meeting, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01256131
Time Accurate Anisotropic Goal-Oriented Mesh Adaptation for Unsteady Flows, J. Comp. Phys, vol.231, p.6348, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00940095
An optimization framework for anisotropic simplex mesh adaptation: application to aerodynamics flows, pp.2012-0079, 2012. ,
Anisotropic mesh adaptation for crack propagation induced by a thermal shock in 2D, Comput. Methods Appl. Mech. Engrg, vol.331, pp.138-158, 2018. ,
Anisotropic a priori error estimates for elliptic problems, Numer. Math, vol.94, pp.67-92, 2003. ,
Higher order solution of the Euler equations on unstructured grids using quadratic reconstruction, pp.90-103, 1990. ,
A-posteriori error estimation for higher order godunov finite volume methods on unstructured meshes, Finite Volumes for Complex Applications III, vol.41, p.63, 2002. ,
High-order solution-adaptive central essentially nonoscillatory (CENO) method for viscous flows, J. Comp. Phys, vol.257, pp.830-862, 2014. ,
Anisotropic goal-oriented error analysis for a third-order accurate CENO Euler discretization, Int. J. Num. Meth. in Fluids, vol.86, issue.6, p.413, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01579998
Analyse et adaptation de maillage pour des schémas non-oscillatoires d'ordré elevé, 2013. ,
Very High Order Anisotropic Metric-Based Mesh Adaptation in 3D, 25th International Meshing Roundtable. Procedia Engineering, vol.163, pp.353-365, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01438226
Nonlinear corrector for RANS equations, AIAA conf, 2018. ,
A mesh-adaptative metric-based full multigrid for the Poisson problem, Int. J. Num. Meth. in Fluids, vol.30, p.53, 2015. ,
Alauzet, A. Dervieux, A priori errorbased mesh adaptation in CFD, special issue of Journal of Methods and Applications of Analysis, 2018. ,
