S. E. Benzley, K. E. Perry, B. C. Merkley, and G. Sjaardema, A comparison of all-hexahedral and alltetrahedral finite element meshes for elastic and elasto-plastic analysis, International Meshing Roundtable conf. proc, 1995.
T. D. Blacker and R. J. Meyers, Seams and wedges in plastering: A 3-d hexahedral mesh generation algorithm, Engineering with Computers, vol.9, issue.2, pp.83-93, 1993.
A. Nestor, . Calvo, and . Sergio-r-idelsohn, All-hexahedral element meshing: Generation of the dual mesh by recurrent subdivision, Computer Methods in Applied Mechanics and Engineering, vol.182, issue.3-4, pp.371-378, 2000.
T. Carrier-baudouin, J. Remacle, E. Marchandise, F. Henrotte, and C. Geuzaine, A frontal approach to hex-dominant mesh generation, Advanced Modeling and Simulation in Engineering Sciences, vol.1, issue.1, 2014.
R. Chouadria and P. Véron, Identifying and re-meshing contact interfaces in a polyhedral assembly for digital mock-up, vol.22, pp.47-58, 2006.
B. Clark, B. W. Hanks, and C. Ernst, Conformal assembly meshing with tolerant imprinting, vol.01, 2008.
X. Fang, W. Xu, H. Bao, and J. Huang, Allhex meshing using closed-form induced polycube, ACM Trans. Graph, vol.35, issue.4, 2016.
X. Gao, W. Jakob, M. Tarini, and D. Panozzo, Robust hexdominant mesh generation using field-guided polyhedral agglomeration, ACM TOG (SIGGRAPH conf, p.2017
J. Gregson, A. Sheffer, and E. Zhang, All-hex mesh generation via volumetric polycube deformation, Computer Graphics Forum (Special Issue of Symposium on Geometry Processing, vol.30, issue.5, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00766792
J. Huang, Y. Tong, H. Wei, and H. Bao, Boundary aligned smooth 3d cross-frame field, ACM Trans. Graph, vol.30, issue.6, 2011.
T. Jiang, J. Huang, Y. Wang, Y. Tong, and H. Bao, Frame field singularity correction for automatic hexahedralization, IEEE Transactions on Visualization and Computer Graphics, vol.20, issue.8, pp.1189-1199, 2014.
Y. Li, Y. Liu, W. Xu, W. Wang, and B. Guo, All-hex meshing using singularity-restricted field, ACM Trans. Graph, vol.31, issue.6, pp.1-177, 2012.
M. Lyon, D. Bommes, and L. Kobbelt, HexEx: Robust hexahedral mesh extraction, ACM Trans. Graph, 2016.
L. Maréchal, A new approach to octree-based hexahedral meshing, International Meshing Roundtable conf. proc, 2001.
J. Ray, T. J. Meyers, P. M. Tautges, . Tuchinsky, . Dr et al., The "hex-tet" hex-dominant meshing algorithm as implemented in cubit, CUBIT; Proceedings, 7 th International Meshing Roundtable 98, pp.151-158, 1998.
M. Müller-hannemann, Hexahedral mesh generation by successive dual cycle elimination, Engineering with Computers, vol.15, issue.3, pp.269-279, 1999.
M. Nieser, U. Reitebuch, and K. Polthier, Cubecover-parameterization of 3d volumes, Computer Graphics Forum, vol.30, issue.5, pp.1397-1406, 2011.
J. Steven, S. Owen, and . Saigal, H-morph: an indirect approach to advancing front hex meshing, International Journal for Numerical Methods in Engineering, vol.49, issue.1-2, pp.289-312, 2000.
N. Ray, D. Sokolov, and B. Lévy, Practical 3d frame field generation, ACM Trans. Graph, vol.35, issue.6, pp.1-233, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01397711
H. Si, Tetgen, a delaunay-based quality tetrahedral mesh generator, ACM Trans. Math. Softw, vol.41, issue.2, pp.1-11, 2015.
D. Sokolov, N. Ray, L. Untereiner, and B. Lévy, Hexahedral-dominant meshing, ACM Trans. Graph, vol.35, issue.5, p.23, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01203544
T. J. Tautges, T. Blacker, and S. A. Mitchell, The whisker weaving algorithm: A connectivity-based method for constructing all-hexahedral finite element meshes, International Journal for Numerical Methods in Engineering, vol.39, issue.19, pp.3327-3349, 1996.
R. David, P. White, and . Kinney, Redesign of the Paving Algorithm: Robustness Enhancements through Element by Element Meshing, Proceedings of the 6th Iternational Meshing Roundtable, pp.323-335, 1997.
Y. Zhang and C. Bajaj, Adaptive and quality quadrilateral/hexahedral meshing from volumetric data, In International Meshing Roundtable conf. proc, 2004.
