Journal articles
A Finite-Difference Method for the Variable Coefficient Poisson Equation on Hierarchical Cartesian Meshes
Abstract : We consider problems governed by a linear elliptic equation with varying coefficients across internal interfaces. The solution and its normal derivative can undergo significant variations through these internal boundaries. We present a compact finite-difference scheme on a tree-based adaptive grid that can be efficiently solved using a natively parallel data structure. The main idea is to optimize the truncation error of the discretization scheme as a function of the local grid configuration to achieve second-order accuracy. Numerical illustrations are presented in two and three-dimensional configurations. Finite difference method; Hierarchical Cartesian grid; Octree/Quadtree; Variable coefficient Poisson equation 1
Complete list of metadatas
Cited literature [16 references]  Display  Hide  Download
https://hal.inria.fr/hal-01662050
Contributor : Alice Raeli <>
Submitted on : Wednesday, December 13, 2017 - 9:25:37 AM
Last modification on : Monday, January 13, 2020 - 11:08:09 AM
File
RaeliBergmannIollo (1).pdf
Identifiers
Collections
Citation
Alice Raeli, Michel Bergmann, Angelo Iollo. A Finite-Difference Method for the Variable Coefficient Poisson Equation on Hierarchical Cartesian Meshes. Journal of Computational Physics, Elsevier, 2017, 355, pp.59-77. ⟨10.1016/j.jcp.2017.11.007⟩. ⟨hal-01662050⟩
Share
Metrics
Record views
284
Files downloads
1828
