Representation and Control of Infinite Dimensional Systems, 2007. ,
Mixed and Hybrid Finite Element Methods, 1991. ,
Stabilized explicit coupling for fluid-structure interaction using Nitsche's method, Comptes Rendus Mathematique, vol.345, issue.8, pp.467-472, 2007. ,
DOI : 10.1016/j.crma.2007.09.010
URL : http://hal.archives-ouvertes.fr/docs/00/33/33/22/PDF/RR-6445.pdf
Stabilization of explicit coupling in fluid-structure interaction involving fluid incompressibility, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5, pp.766-784, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00247409
Effective and energy-preserving time discretization for a general nonlinear poromechanical formulation, Computers and Structures, vol.182, issue.x, pp.313-324, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01395508
General coupling of porous flows and hyperelastic formulations-From thermodynamics principles to energy balance and compatible time schemes, European Journal of Mechanics-B/Fluids, vol.46, pp.82-96, 2014. ,
URL : https://hal.archives-ouvertes.fr/inria-00520612
Mathematical Elasticity-Volume I: Three-Dimensional Elasticity, 1988. ,
Approximation by finite element functions using local regularization. Revue francaise d'automatique, informatique, recherche opérationnelle. Analyse numérique, vol.9, pp.77-84, 1975. ,
An arbitrary Lagrangian-Eulerian finite element formulation for a poroelasticity problem stemming from mixture theory, Comput Method Appl M, vol.323, pp.64-97, 2017. ,
, , 2004.
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.69, issue.4, pp.794-821, 2007. ,
A Quasi-Newton Algorithm Based on a Reduced Model for Fluid-Structure Interaction Problems in Blood Flows, ESAIM: M2AN, vol.37, issue.4, pp.631-647, 2003. ,
URL : https://hal.archives-ouvertes.fr/inria-00071895
New development in FreeFem++, J. Numer. Math, vol.20, issue.3-4, pp.251-265, 2012. ,
DOI : 10.1515/jnum-2012-0013
URL : https://hal.archives-ouvertes.fr/hal-01476313
Energy conservation in fluid structure interactions, Numerical Methods for Scientific Computing / Variational Problems and Applications-CIMNE, 2003. ,
Non-Homogeneous Boundary Value Problems and Applications, vol.1, 1972. ,
DOI : 10.1007/978-3-642-65161-8
Uber ein Variationsprinzip zur Lösung von Dirichlet-Problemen bei Verwendung von Teilräumen, die keinen Randbedingungen unterworfen sind, Abh. Math. Sem. Univ. Hamburg, vol.36, pp.9-15, 1971. ,
DOI : 10.1007/bf02995904
Two finite element approaches for Darcy and Darcy-Brinkman flow through deformable porous media-Mixed method vs, NURBS based (isogeometric) continuity. Comput Method Appl M, vol.305, pp.634-657, 2016. ,
DOI : 10.1016/j.cma.2016.03.005
