Fast Linear Attitude Estimation and Angular Rate Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This paper focuses on the design of an approach to estimate attitude Euler angles and virtual gyroscope output based on a linear Kalman filter and attitude information compensation. First, the rotation transformation is built between the body frame and the reference frame by means of an accelerometer-magnetometer triad. The attitude quaternion is invoked for parameterization of orientation which leads to the Kalman filter fusing also the angular rate measurements. Furthermore, to compute the virtual-gyro output in the case of gyroscope failures and obtain bias-free angular rate estimates, virtual gyro Kalman filter is that forms a novel angular rate estimation approach. Some experiment scenarios are given to illustrate the validity and efficiency of the proposed attitude and angular rate estimation approaches.
Final version_May 2018.pdf (613.46 Ko) Télécharger le fichier
hal-01928684 , version 1 (20-11-2018)
Zeliang Zhang, Zebo Zhou, Jin Wu, Shuang Du, Hassen Fourati. Fast Linear Attitude Estimation and Angular Rate Generation. IPIN 2018 - International Conference on Indoor Positioning and Indoor Navigation, Sep 2018, Nantes, France. pp.1-7, ⟨10.1109/IPIN.2018.8533736⟩. ⟨hal-01928684⟩
79 Consultations
254 Téléchargements
