Efficient computation of the position, velocity and time estimation algorithm on a GNSS processor using interpolation, Satellite Navigation Technologies and European Workshop on Gnss Signals and Signal Processing IEEE, pp.1-7, 2012. ,
Integrated navigation system for a low-cost quadrotor aerial vehicle in the presence of rotors influences, Journal of Surveying Engineering, vol.143, issue.1, 2017. ,
Inertial navigation system analysis, Avionics, 1971. ,
Attitude and heading reference system with acceleration compensation, Aircraft Engineering and Aerospace Technology, vol.84, issue.2, pp.87-93, 2012. ,
Design and implementation of an AHRS based on MEMS sensors and complementary filtering, Advances in Mechanical Engineering, pp.1-11, 2014. ,
Low-cost Attitude and Heading Reference System: Filter design and experimental evaluation, IEEE International Conference on Robotics and Automation, pp.2624-2629, 2010. ,
Optimal Recursive and Sub-Optimal Linear Solutions to Attitude Determination from Vector Observations for GNSS/Accelerometer/Magnetometer Orientation Measurement, Remote sensing, vol.10, issue.3, p.377, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01722260
Orientation estimation using a quaternion-based indirect kalman filter with adaptive estimation of external acceleration, IEEE Transactions on Instrumentation and Measurement, vol.59, issue.12, pp.3296-3305, 2010. ,
A coupled nonlinear spacecraft attitude controller/observer with an unknown constant gyro bias, Decision and Control, vol.4, pp.3441-3446, 2001. ,
Fast Complementary Filter for Attitude Estimation Using Low-Cost MARG Sensors, IEEE Sensors Journal, vol.16, issue.18, pp.6997-7007, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01368473
A nonlinear complementary filter approach for MAV 3D-attitude estimation with low-cost MARG/ADS. Position, Location and Navigation Symposium IEEE, pp.42-47, 2016. ,
Aerospace Sensor Systems and Applications, vol.9, 1998. ,
Equality constrained robust measurement fusion for adaptive Kalman filter based heterogeneous multi-sensor navigation, IEEE Transactions on Aerospace and Electronic Systems, vol.49, issue.4, pp.2146-2157, 2013. ,
Applying the unscented Kalman filter for nonlinear state estimation, Journal of Process Control, vol.18, pp.753-768, 2008. ,
An extended Kalman filter for quaternion-based orientation estimation using MARG sensors, International Conference on Intelligent Robots and Systems, vol.4, 2001. ,
DOI : 10.1109/iros.2001.976367
URL : https://calhoun.nps.edu/bitstream/10945/41567/1/IROS2001.pdf
Critical issues on Kalman filter with colored and correlated system, Asian Journal of Control, vol.20, issue.1, pp.1-15, 2018. ,
DOI : 10.1002/asjc.1545
URL : https://hal.archives-ouvertes.fr/hal-01496860
An adaptive-gain complementary filter for real-time human motion tracking with MARG sensors in free-living environments, IEEE Transactions on Neural Systems and Rehabilitation Engineering, pp.254-264, 2013. ,
DOI : 10.1109/tnsre.2012.2205706
An improved quaternion GaussC Newton algorithm for attitude determination using magnetometer and accelerometer, China J. Aeronautics, vol.27, issue.4, pp.986-993, 2014. ,
DOI : 10.1016/j.cja.2014.03.005
URL : https://doi.org/10.1016/j.cja.2014.03.005
A Least Squares Estimate of Satellite Attitude, J]. Siam Review, vol.7, issue.3, pp.409-409, 1965. ,
DOI : 10.1137/1007077
Compensation of magnetic disturbances improves inertial and magnetic sensing of human body segment orientation, IEEE Transactions on Neural Systems and Rehabilitation Engineering A Publication of the IEEE Engineering in Medicine and Biology Society, vol.13, issue.3, p.395, 2005. ,
DOI : 10.1109/tnsre.2005.847353
URL : http://www.eecs.harvard.edu/~konrad/projects/thesis/relatedWork/spaulding/CompensationOfMagneticDisturbancesImprovesInertialAndMagnetic.pdf
Design of an Angular-Rate Compensation Based Strap-down Antenna Stabilization System. Electronics Optics and Control, 2010. ,
Building a virtual gyro, 2013. ,
Novel quaternion kalman filter, Aerospace and Electronic Systems IEEE Transactions on, vol.42, pp.174-190, 2002. ,
DOI : 10.1109/taes.2006.1603413
URL : https://cloudfront.escholarship.org/dist/prd/content/qt16m98742/qt16m98742.pdf
Attitude determination from vector observations: A fast optimal matrix algorithm, J. Astron. Sci, vol.41, issue.2, pp.261-280, 1993. ,
Three-axis attitude determination from vector observations, J Guidance Control Dynam, vol.4, issue.1, pp.70-77, 1981. ,
Stability of a nonlinear attitude observer on SO(3) with nonideal angular velocity measurements, Control Conference. IEEE, pp.2769-2774, 2009. ,
DOI : 10.23919/ecc.2009.7074826
Fast Linear Quaternion Attitude Estimator Using Vector Observations, IEEE Transactions on Automation Science and Engineering, vol.15, issue.1, pp.307-319, 2018. ,
DOI : 10.1109/tase.2017.2699221
URL : https://hal.archives-ouvertes.fr/hal-01513263
Applications of magnetic sensors for low cost compass systems. Position Location and Navigation Symposium, pp.177-184, 2002. ,
DOI : 10.1109/plans.2000.838300
An Introduction to the Kalman Filter, 2001. ,
A nonlinear position and attitude observer on SE(3) using landmark measurements, Systems and Control Letters, vol.59, issue.3, pp.155-166, 2010. ,
DOI : 10.1016/j.sysconle.2009.11.008
A nonlinear ?ltering approach for the attitude and dynamic body acceleration estimation based on inertial and magnetic sensors: Bio-logging application, IEEE Sensors Journal, vol.11, issue.1, pp.233-244, 2011. ,
DOI : 10.1109/jsen.2010.2053353
URL : http://hal.inria.fr/docs/00/62/41/42/PDF/Papier_IEEE_Sensors_Journal.pdf
Complementary observer for body segments motion capturing by inertial and magnetic sensors, IEEE/ASME Trans. Mechatronics, vol.19, issue.1, pp.149-157, 2014. ,
DOI : 10.1109/tmech.2012.2225151
URL : https://hal.archives-ouvertes.fr/hal-00690145
Angular rate estimation using a distributed set of accelerometers, Sensors, vol.11, issue.11, pp.10444-10457, 2011. ,
DOI : 10.3390/s111110444
URL : https://www.mdpi.com/1424-8220/11/11/10444/pdf
An effective unscented Kalman filter for state estimation of a gyro-free inertial measurement unit. Position, Location and Navigation Symposium-PLANS, pp.230-235, 2014. ,
DOI : 10.1109/plans.2014.6851380
