Well-posedness of IBVP for 1D scalar non-local conservation laws - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Mathematics and Mechanics / Zeitschrift für Angewandte Mathematik und Mechanik Année : 2019
We consider the initial boundary value problem (IBVP) for a non-local scalar conservation laws in one space dimension. The non-local operator in the flux function is not a mere convolution product, but it is assumed to be aware of boundaries. Introducing an adapted Lax-Friedrichs algorithm, we provide various estimates on the approximate solutions that allow to prove the existence of solutions to the original IBVP. The uniqueness follows from the Lipschitz continuous dependence on initial and boundary data, which is proved exploiting results available for the local IBVP.
ibvp2.pdf (327.41 Ko) Télécharger le fichier
hal-01929196 , version 1 (21-11-2018)
Paola Goatin, Elena Rossi. Well-posedness of IBVP for 1D scalar non-local conservation laws. Journal of Applied Mathematics and Mechanics / Zeitschrift für Angewandte Mathematik und Mechanik, 2019, 99 (11), ⟨10.1002/zamm.201800318⟩. ⟨hal-01929196⟩
276 Consultations
126 Téléchargements
