Sharing a Library between Proof Assistants: Reaching out to the HOL Family * - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Electronic Proceedings in Theoretical Computer Science Année : 2018
We observe today a large diversity of proof systems. This diversity has the negative consequence that a lot of theorems are proved many times. Unlike programming languages, it is difficult for these systems to cooperate because they do not implement the same logic. Logical frameworks are a class of theorem provers that overcome this issue by their capacity of implementing various logics. In this work, we study the STT∀ βδ logic, an extension of Simple Type Theory that has been encoded in the logical framework Dedukti [6]. We present a translation from this logic to OpenTheory [8], a proof system and interoperability tool between provers of the HOL family. We have used this translation to export an arithmetic library containing Fermat's little theorem to OpenTheory and to two other proof systems that are Coq [13] and Matita [2].
sttforall-lfmtp.pdf (504.54 Ko) Télécharger le fichier
hal-01929714 , version 1 (21-11-2018)
François Thiré. Sharing a Library between Proof Assistants: Reaching out to the HOL Family *. Electronic Proceedings in Theoretical Computer Science, 2018, 274, pp.57 - 71. ⟨10.4204/EPTCS.274.5⟩. ⟨hal-01929714⟩
76 Consultations
192 Téléchargements
