Robust coarse spaces for abstract Schwarz preconditioners via generalized eigenproblems, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01670178
Post-failure recovery of MPI communication capability: Design and rationale, vol.IJHPCA, pp.244-254, 2013. ,
Inexact matrix-vector products in Krylov methods for solving linear systems: a relaxation strategy, SIAM Journal on Matrix Analysis and Applications, vol.26, issue.23, pp.660-678, 2005. ,
A relaxation strategy for inner-outer linear solvers in domain decomposition methods, CERFACS, 2000. ,
Quantifying the Impact of Single Bit Flips on Floating Point Arithmetic, pp.1-13, 2013. ,
Evaluating the impact of sdc on the gmres iterative solver, Parallel and Distributed Processing Symposium, pp.1193-1202, 2014. ,
Resilience in Numerical Methods: A Position on Fault Models and Methodologies, 2014. ,
Mpi: A message passing interface standard version 3.1, 2015. ,
Mixed-precision in-memory computing, Nature Electronics, vol.1, pp.246-253, 2018. ,
PVM: Parallel virtual machine: a users' guide and tutorial for networked parallel computing, 1994. ,
Hiding global synchronization latency in the preconditioned Conjugate Gradient algorithm, Parallel Computing, vol.40, issue.7, pp.224-238, 2014. ,
Estimating the attainable accuracy of recursively computed residual methods, SIAM Journal on Matrix Analysis and Applications, vol.18, issue.3, pp.535-551, 1997. ,
Accuracy of two three-term and three two-term recurrences for Krylov space solvers, SIAM Journal on Matrix Analysis and Applications, vol.22, issue.1, pp.213-229, 2000. ,
Finding structure with randomness: Probabilistic algorithms for constructing approximate matrix decompositions, SIAM Review, vol.53, issue.2, pp.217-288, 2011. ,
, Fault-Tolerance Techniques for High-Performance Computing, 2015.
Methods of conjugate gradients for solving linear systems, Journal of Research of the National Bureau of Standards, vol.46, issue.6, pp.409-436, 1952. ,
Accuracy and Stability of Numerical Algorithms, Society for Industrial and Applied Mathematics, 2002. ,
Fault-tolerant iterative methods via selective reliability. Proceedings of the, 2011. ,
Algorithm-Based Fault Tolerance for Matnx Operations, IEEE Transactions on Computers, issue.6, pp.518-528, 1984. ,
, Krylov Subspace Methods. Numerical Mathematics and Scientific Computation, 2013.
The Lanczos and conjugate gradient algorithms in finite precision arithmetic, vol.15, 2006. ,
, or failure? IEEE Transactions on Reliability, vol.46, pp.450-451, 1997.
Iterative Methods for Sparse Linear Systems, Society for Industrial and Applied Mathematics, 2003. ,
Self-stabilizing iterative solvers, Proceedings of the Workshop on Latest Advances in Scalable Algorithms for Large-Scale Systems-ScalA '13, pp.1-8, 2013. ,
Characterizing the impact of soft errors on iterative methods in scientific computing, Proceedings of the international conference on Supercomputing-ICS '11, p.152, 2011. ,
Theory of inexact Krylov subspace methods and applications to scientific computing, SIAM Journal Scientific Computing, vol.25, pp.454-477, 2003. ,
Error estimation in preconditioned conjugate gradients, BIT Numerical Mathematics, pp.789-817, 2005. ,
Cambridge monographs on applied and computational mathematics, 2003. ,
Residual replacement strategies for Krylov subspace iterative methods for the convergence of true residuals, SIAM Journal Scientific Computing, vol.22, issue.3, pp.835-852, 2000. ,
Radiation effects on embedded systems, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00185087
