A Fast Randomized Geometric Algorithm for Computing Riemann-Roch Spaces
We propose a probabilistic variant of Brill-Noether's algorithm for computing a basis of
the
Riemann-Roch space $L(D)$ associated to a divisor $D$ on a projective nodal plane curve
$\mathcal C$ over a sufficiently large perfect field $k$. Our main result shows that this
algorithm requires at most $O(\max(\deg(\mathcal C)^{2\omega}, \deg(D_+)^\omega))$
arithmetic operations in $k$,
where $\omega$ is a feasible exponent for matrix multiplication and $D_+$ is the
smallest effective divisor such that $D_+\geq D$. This improves the
best known upper bounds on the complexity of computing Riemann-Roch spaces.
Our algorithm may fail, but we show that provided that a few mild assumptions
are satisfied, the failure probability is bounded by $O(\max(\deg(\mathcal C)^4,
\deg(D_+)^2)/\lvert \mathcal E\rvert)$, where $\mathcal E$
is a finite subset of $k$ in which we pick elements uniformly at random.
We provide a freely available C++/NTL implementation of the proposed algorithm
and we present experimental data. In particular, our
implementation enjoys a speedup larger than 6 on many examples (and larger than 200 on some
instances over large finite
fields)
compared to the reference implementation in the Magma computer algebra system.
As a by-product, our algorithm also yields a method for computing the group
law on the Jacobian of a smooth plane curve of genus $g$ within $O(g^\omega)$
operations in $k$, which equals the best known complexity for this problem.
