The h, p and h-p versions of the finite element method in 1 dimension. II. The error analysis of the h-and h-p versions, Numer. Math, vol.49, issue.6, pp.613-657, 1986. ,
The h, p and h-p versions of the finite element method in 1 dimension. III. The adaptive h-p version, Numer. Math, vol.49, issue.6, pp.659-683, 1986. ,
The h-p version of finite element method, part 1: The basic approximation results, Comp. Mech, issue.1, pp.21-41, 1986. ,
The h-p version of finite element method, part 2: General results and application, Comp. Mech, issue.1, pp.203-220, 1986. ,
Theory of adaptive finite element methods: an introduction, Multiscale, nonlinear and adaptive approximation, pp.409-542, 2009. ,
An optimal adaptive finite element method, SIAM J. Numer. Anal, vol.42, issue.5, pp.2188-2217, 2005. ,
Optimality of a standard adaptive finite element method, Found, Comput. Math, vol.7, issue.2, pp.245-269, 2007. ,
Stopping criteria for adaptive finite element solvers, SIAM, J. Sci. Comput, vol.35, issue.3, 2013. ,
DOI : 10.1137/120867421
Interplay between discretization and algebraic computation in adaptive numerical solution of elliptic PDE problems, GAMM-Mitt, vol.36, issue.1, pp.102-129, 2013. ,
Adaptive finite element methods with inexact solvers for the nonlinear Poisson-Boltzmann equation, Domain decomposition methods in science and engineering XX, vol.91, pp.167-174, 2013. ,
Axioms of adaptivity, Comput. Math. Appl, vol.67, issue.6, pp.1195-1253, 2014. ,
DOI : 10.1016/j.camwa.2013.12.003
URL : https://doi.org/10.1016/j.camwa.2013.12.003
Rate optimal adaptive FEM with inexact solver for nonlinear operators, IMA J. Numer. Anal, 2017. ,
Adaptive error control for multigrid finite element methods, Computing, vol.55, issue.4, pp.271-288, 1995. ,
DOI : 10.1007/bf02238483
Adaptive inexact Newton methods with a posteriori stopping criteria for nonlinear diffusion PDEs, SIAM J. Sci. Comput, vol.35, issue.4, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00681422
An adaptive hp-refinement strategy with computable guaranteed bound on the error reduction factor, Computers and Mathematics with Applica, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01666763
hp-adaptation driven by polynomial-degree-robust a posteriori error estimates for elliptic problems, SIAM J. Sci. Comput, vol.38, issue.5, 2016. ,
Sharp algebraic and total a posteriori error bounds for h and p finite elements via a multilevel approach, HAL preprint, p.1662944, 2017. ,
A convergent adaptive algorithm for Poisson's equation, SIAM J. Numer. Anal, vol.33, issue.3, pp.1106-1124, 1996. ,
Estimating and localizing the algebraic and total numerical errors using flux reconstructions, Numer. Math, vol.138, issue.3, pp.681-721, 2018. ,
Explicit error bounds in a conforming finite element method, Math. Comp, vol.68, issue.228, pp.1379-1396, 1999. ,
Equilibrated residual error estimates are p-robust, Comput. Methods Appl. Mech. Engrg, vol.198, pp.1189-1197, 2009. ,
Polynomial-degree-robust a posteriori estimates in a unified setting for conforming, nonconforming, discontinuous Galerkin, and mixed discretizations, SIAM J. Numer. Anal, vol.53, issue.2, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00921583
Stable broken H 1 and H(div) polynomial extensions for polynomial-degree-robust potential and flux reconstruction in three space dimensions, HAL Preprint, p.1422204, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01422204
A posteriori error estimates including algebraic error and stopping criteria for iterative solvers, SIAM J. Sci. Comput, vol.32, issue.3, 2010. ,
A strict error bound with separated contributions of the discretization and of the iterative solver in non-overlapping domain decomposition methods, Comput. Methods Appl. Mech. Engrg, vol.270, pp.293-303, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00919435
The finite element method and its reliability, Numerical Mathematics and Scientific Computation, 2001. ,
A posteriori estimates for partial differential equations, Radon Series on Computational and Applied Mathematics, vol.4, 2008. ,
, Springer Series in Computational Mathematics, vol.15, 1991.
Mixed and hybrid methods, Handbook of Numerical Analysis, vol.II, pp.523-639, 1991. ,
URL : https://hal.archives-ouvertes.fr/inria-00075815
Automatic generation of triangulations for piecewise polynomial approximation, ProQuest LLC, 1972. ,
A comparison of adaptive refinement techniques for elliptic problems, ACM Trans. Math. Software, vol.15, issue.4, pp.326-347, 1989. ,
revised reprint of "Data oscillation and convergence of adaptive FEM, SIAM J. Numer. Anal, vol.44, issue.4, pp.466-488, 2000. ,
A posteriori error estimation techniques for finite element methods, Numerical Mathematics and Scientific Computation, 2013. ,
A comparison of hp-adaptive strategies for elliptic partial differential equations (long version, 2011. ,
Finite element analysis, 1991. ,
Localization of global norms and robust a posteriori error control for transmission problems with sign-changing coefficients, M2AN Math. Model. Numer. Anal, vol.52, issue.5, pp.2037-2064, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01148476
Guaranteed and robust a posteriori bounds for Laplace eigenvalues and eigenvectors: conforming approximations, SIAM J. Numer. Anal, vol.55, issue.5, pp.2228-2254, 2017. ,
Simple and robust equilibrated flux a posteriori estimates for singularly perturbed reaction-diffusion problems, HAL Preprint 01956180, 2018. ,
Goal-oriented a posteriori error estimation for conforming and nonconforming approximations with inexact solvers, HAL Preprint 01964733, 2018. ,
Guaranteed, locally space-time efficient, and polynomial-degree robust a posteriori error estimates for high-order discretizations of parabolic problems, SIAM J. Numer. Anal, vol.55, issue.6, pp.2811-2834, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01377086
