GABAergic cells are the major postsynaptic targets of mossy fibers in the rat hippocampus, J Neurosci, vol.18, pp.3386-3403, 1998. ,
Computational influence of adult neurogenesis on memory encoding, Neuron, vol.61, pp.187-202, 2009. ,
Hippocampal granule cells opt for early retirement, Hippocampus, vol.20, pp.1109-1132, 2010. ,
DOI : 10.1002/hipo.20810
Effects of novelty, pain and stress on hippocampal extracellular acetylcholine levels in male rats, Brain Res, vol.748, pp.219-245, 1997. ,
The dentate gyrus: fundamental neuroanatomical organization (dentate gyrus for dummies), Prog Brain Res, vol.163, pp.3-22, 2007. ,
Characteristics of sparsely encoded associative memory, Neural Networks, vol.2, issue.6, pp.451-457, 1989. ,
DOI : 10.1016/0893-6080(89)90043-9
Lamellar organization of hippocampal excitatory pathways, Exp. Brain Res, vol.13, pp.222-238, 1971. ,
, Pattern separation in the human hippocampal CA3 and dentate gyrus, vol.319, pp.1640-1642, 2008.
Strong evidence for pattern separation in human dentate gyrus, J Neurosci, vol.36, pp.7569-79, 2016. ,
Adrenergic modulation of hilar neuron activity and granule cell inhibition in the guineapig hippocampal slice, Neuroscience, vol.67, pp.541-50, 1995. ,
Long-lasting potentiation of synaptic transmission in the dentate area of the anaesthetized rabbit following stimulation of the perforant path, J Physiol, vol.232, pp.331-356, 1973. ,
Hippocampal mossy cell function: a speculative view, Hippocampus, vol.4, pp.393-402, 1994. ,
DOI : 10.1002/hipo.450040402
Axon arbors and synaptic connections of hippocampal mossy cells in the rat in vivo, J Comp Neurol, vol.366, pp.271-92, 1996. ,
Hilar mossy cells provide the first glutamatergic synapses to adult-born dentate granule cells, Journal of Neuroscience, vol.34, pp.2349-2354, 2014. ,
Sparse, environmentally selective expression of Arc RNA in the upper blade of the rodent fascia dentata by brief spatial experience, Hippocampus, vol.15, pp.579-586, 2005. ,
A functional role for adult hippocampal neurogenesis in spatial pattern separation, Science, vol.325, pp.210-213, 2009. ,
Learning spatial orientation tasks in the radial-maze and structural variation in the hippocampus in inbred mice, Behav Brain Funct, vol.1, p.3, 2005. ,
Activation of metabotropic glutamate receptor type 2/3 supports the involvement of the hippocampal mossy fiber pathway on contextual fear memory consolidation, Learn Mem, vol.16, pp.504-511, 2009. ,
Disruption of hippocampal CA3 network: effects on episodic-like memory processing in c57bl/6j mice, European Journal of Neuroscience, vol.20, pp.597-600, 2004. ,
Memory retrieval time and memory capacity of the CA3 network: role of gamma frequency oscillations, Learn Mem, vol.14, pp.795-806, 2007. ,
A novel entorhinal projection to the rat dentate gyrus: direct innervation of proximal dendrites and cell bodies of granule cells and GABAergic neurons, J. Neurosci, vol.16, pp.3322-3355, 1996. ,
Selection of distinct populations of dentate granule cells in response to inputs as a mechanism for pattern separation in mice, eLife, vol.2, p.312, 2013. ,
Distinct determinants of sparse activation during granule cell maturation, J Neurosci, vol.33, pp.19131-19173, 2013. ,
Expression of c-fos in hilar mossy cells of the dentate gyrus in vivo, Hippocampus, vol.23, pp.649-55, 2013. ,
, Hippocampus: cognitive processes and neural representations that underlie declarative memory, vol.44, pp.109-129, 2004.
, Interneurons of the hippocampus, vol.6, pp.347-470, 1996.
URL : https://hal.archives-ouvertes.fr/inserm-00484796
, Epha4 signaling in juveniles establishes topographic specificity of structural plasticity in the hippocampus, vol.65, pp.627-669, 2010.
A critical period for enhanced synaptic plasticity in newly generated neurons of the adult brain, Neuron, vol.54, pp.559-66, 2007. ,
Dissociating hippocampal subregions: double dissociation between dentate gyrus and ca1, Hippocampus, vol.11, pp.626-662, 2001. ,
Computational models of the hippocampal region: linking incremental learning and episodic memory, vol.7, pp.269-276, 2003. ,
The interactions and dissociations of the dorsal hippocampus subregions: how the dentate gyrus, CA3, and CA1 process spatial information, Behav Neurosci, vol.122, pp.16-26, 2008. ,
Norepinephrine and the dentate gyrus, Prog Brain Res, vol.163, pp.299-318, 2007. ,
A proposed function for hippocampal theta rhythm: Separate phases of encoding and retrieval enhance reversal of prior learning, Neural Comput, vol.14, pp.793-817, 2002. ,
Encoding and retrieval of episodic memories: Role of cholinergic and GABAergic modulation in the hippocampus, Hippocampus, vol.6, pp.693-708, 1996. ,
Ipsilateral associational pathway in the dentate gyrus: an excitatory feedback system that supports N-methyl-D-aspartate-dependent long-term potentiation, Hippocampus, vol.4, pp.422-460, 1994. ,
The role of the dentate gyrus, CA3a,b, and CA3c for detecting spatial and environmental novelty, Hippocampus, vol.18, pp.1064-73, 2008. ,
Organization of intrahippocampal projections originating from ca3 pyramidal cells in the rat, J Comp Neurol, vol.295, pp.580-623, 1990. ,
Positive feedback from hilar mossy cells to granule cells in the dentate gyrus revealed by voltage-sensitive dye and microelectrode recording, J Neurophysiol, vol.76, pp.601-617, 1996. ,
Hilar mossy cell degeneration causes transient dentate granule cell hyperexcitability and impaired pattern separation, Neuron, vol.76, pp.1189-200, 2012. ,
Integration of exteroceptive and interoceptive information within the hippocampus: a computational study, Front Syst Neurosci, vol.5, p.87, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01237876
Preferential incorporation of adult-generated granule cells into spatial memory networks in the dentate gyrus, Nat Neurosci, vol.10, pp.355-62, 2007. ,
Motivational states activate distinct hippocampal representations to guide goaldirected behaviors, Proc. Natl. Acad. Sci. U.S.A, vol.106, pp.10805-10810, 2009. ,
Long-term potentiation recruits a trisynaptic excitatory associative network within the mouse dentate gyrus, Eur J Neurosci, vol.17, pp.2690-702, 2003. ,
, Memory capacities for synaptic and structural plasticity, vol.22, pp.289-341, 2010.
Dendritic integration in hippocampal dentate granule cells, Neuron, vol.71, pp.512-540, 2011. ,
Nonrandom local circuits in the dentate gyrus, J Neurosci, vol.28, pp.12212-12235, 2008. ,
Representing information in cell assemblies: persistent activity mediated by semilunar granule cells, Nat Neurosci, vol.13, pp.213-235, 2010. ,
Reversible inactivation of the hippocampal mossy fiber synapses in mice impairs spatial learning, but neither consolidation nor memory retrieval, in the Morris navigation task, Neurobiol Learn Mem, vol.73, pp.243-57, 2000. ,
Pattern separation of emotional information in hippocampal dentate and CA3, Hippocampus, vol.24, pp.1146-55, 2014. ,
The role of hippocampal subregions in detecting spatial novelty, Behav Neurosci, vol.119, pp.145-53, 2005. ,
Encoding versus retrieval of spatial memory: double dissociation between the dentate gyrus and the perforant path inputs into CA3 in the dorsal hippocampus, Hippocampus, vol.14, pp.66-76, 2004. ,
, Pattern separation in the dentate gyrus and ca3 of the hippocampus, vol.315, pp.961-966, 2007.
The hippocampal ca3 network: an in vivo intracellular labeling study, J Comp Neurol, vol.339, pp.181-208, 1994. ,
Relating hippocampal circuitry to function: Recall of memory sequences by reciprocal dentateCA3 interactions, Neuron, vol.22, pp.233-275, 1999. ,
Mature granule cells of the dentate gyrus-passive bystanders or principal performers in hippocampal function, Neuroscience & Biobehavioral Reviews, vol.64, pp.167-174, 2016. ,
Long-and short-term plasticity at mossy fiber synapses on mossy cells in the rat dentate gyrus, Hippocampus, vol.15, pp.691-697, 2005. ,
A theory of cerebellar cortex, J Physiol, vol.202, pp.437-470, 1969. ,
Simple memory: a theory for archicortex, Philosophical Transactions of the Royal Society of London. Series B, Biological Sciences, vol.262, pp.23-81, 1971. ,
Differential mechanisms of transmission and plasticity at mossy fiber synapses, Prog Brain Res, vol.169, pp.225-240, 2008. ,
Dentate gyrus nmda receptors mediate rapid pattern separation in the hippocampal network, Science, vol.317, pp.94-99, 2007. ,
Hebb-Marr networks and the neurobiological representation of action in space, Neuroscience and Connectionist Theory, pp.1-64, 1990. ,
The contribution of granule cells to spatial representation in hippocampal circuits: A puzzle, pp.110-123, 1991. ,
Episodic-like memory in animals: psychological criteria, neural mechanisms and the value of episodic-like tasks to investigate animal models of neurodegenerative disease, Philos Trans R Soc Lond B Biol Sci, vol.356, pp.1453-1465, 2001. ,
One-shot memory in hippocampal CA3 networks, Neuron, vol.38, issue.2, pp.147-155, 2003. ,
A role for hilar cells in pattern separation in the dentate gyrus: A computational approach, Hippocampus, vol.19, pp.321-337, 2009. ,
Pattern separation in the dentate gyrus: A role for the CA3 backprojection, Hippocampus, vol.21, pp.1190-215, 2011. ,
Young dentate granule cells mediate pattern separation, whereas old granule cells facilitate pattern completion, Cell, vol.149, pp.188-201, 2012. ,
DOI : 10.1016/j.cell.2012.01.046
URL : https://doi.org/10.1016/j.cell.2012.01.046
Hippocampal conjunctive encoding, storage, and recall: Avoiding a trade-off, Hippocampus, 4, vol.6, pp.661-82, 1994. ,
, Conjunctive representations in learning and memory: Principles of cortical and hippocampal function, vol.108, pp.311-345, 2001.
Development of adult-generated cell connectivity with excitatory and inhibitory cell populations in the hippocampus, Journal of Neuroscience, vol.35, pp.10600-10612, 2015. ,
Intragranular mossy fibers in rats and gerbils form synapses with the somata and proximal dendrites of basket cells in the dentate gyrus, Hippocampus, vol.1, pp.355-64, 1991. ,
The mechanisms for pattern completion and pattern separation in the hippocampus, Frontiers in Systems Neuroscience, vol.7, p.74, 2013. ,
Adult hippocampal neurogenesis and plasticity in the infrapyramidal bundle of the mossy fiber projection: I. co-regulation by activity, Neural networks and brain function, vol.5, p.107, 1998. ,
Learning-related feedforward inhibitory connectivity growth required for memory precision, Nature, vol.473, pp.514-522, 2011. ,
DOI : 10.1038/nature09946
Dentate hilar cells with dendrites in the molecular layer have lower thresholds for synaptic activation by perforant path than granule cells, J. Neurosci, vol.11, pp.1660-73, 1991. ,
Evidence from simultaneous intracellular recordings in rat hippocampal slices that area CA3 pyramidal cells innervate dentate hilar mossy cells, J. Neurophysiol, vol.72, pp.2167-80, 1994. ,
Electrophysiological evidence that dentate hilar mossy cells are excitatory and innervate both granule cells and interneurons, J Neurophysiol, vol.74, pp.179-94, 1995. ,
DOI : 10.1152/jn.1995.74.1.179
The CA3 "backprojection" to the dentate gyrus, Prog Brain Res, vol.163, pp.627-664, 2007. ,
DOI : 10.1016/s0079-6123(07)63034-9
URL : http://europepmc.org/articles/pmc1986638?pdf=render
The enigmatic mossy cell of the dentate gyrus, Nat Rev Neurosci, vol.17, pp.562-575, 2016. ,
Structural and functional asymmetry in the normal and epileptic rat dentate gyrus, J Comp Neurol, vol.454, pp.424-463, 2002. ,
DOI : 10.1002/cne.10449
URL : http://europepmc.org/articles/pmc2519114?pdf=render
Loss of recent memory after bilateral hippocampal lesions, Neurosurgery and Psychiatry, vol.20, pp.11-21, 1957. ,
DOI : 10.1093/neucas/2.4.259-af
Norepinephrine-mediated emotional arousal facilitates subsequent pattern separation, Neurobiol Learn Mem, vol.97, pp.465-474, 2012. ,
DOI : 10.1016/j.nlm.2012.03.010
URL : https://cloudfront.escholarship.org/dist/prd/content/qt3hq3516c/qt3hq3516c.pdf?t=n4yr62
Physiological properties and behavioral correlates of hippocampal granule cells and mossy cells, Neuron, vol.93, pp.691-704, 2017. ,
Structure of the granular layer of the rat dentate gyrus. a light microscopic and golgi study, J Anat, vol.133, pp.181-95, 1981. ,
Neurons born in the adult dentate gyrus form functional synapses with target cells, Nat Neurosci, vol.11, pp.901-908, 2008. ,
Computational analysis of the role of the hippocampus in memory, Hippocampus, vol.4, pp.374-391, 1994. ,
What is the mammalian dentate gyrus good for?, Neuroscience, vol.154, pp.1155-72, 2008. ,
Episodic and semantic memory, Organization of Memory, pp.382-402, 1972. ,
Disruption of the direct perforant path input to the ca1 subregion of the dorsal hippocampus interferes with spatial working memory and novelty detection, Behav Brain Res, vol.189, pp.273-83, 2008. ,
, A putative role for neurogenesis in neurocomputational terms: Inferences from a hippocampal model, vol.112, pp.229-240, 2009.
Unbiased stereological estimation of the total number of neurons in the subdivisions of the rat hippocampus using the optical fractionator, Anat Rec, vol.231, pp.482-97, 1991. ,
Attractor dynamics in the hippocampal representation of the local environment, Science, vol.308, pp.873-879, 2005. ,
Non-holographic associative memory, Nature, vol.222, pp.960-962, 1969. ,
A functional hypothesis for adult hippocampal neurogenesis: Avoidance of catastrophic interference in the dentate gyrus, Hippocampus, vol.16, pp.329-372, 2006. ,
Connectivity of the hippocampus, Hippocampal Microcircuits: A Computational Modelers Resource Book, pp.5-26, 2010. ,
Hippocampal CA3 pyramidal cells selectively innervate aspiny interneurons, Eur J Neurosci, vol.24, pp.1286-98, 2006. ,
Pattern separation in the hippocampus, Trends Neurosci, vol.34, pp.515-540, 2011. ,
Protracted postnatal development of sparse, specific dentate granule cell activation in the mouse hippocampus, J Neurosci, vol.33, pp.2947-60, 2013. ,
