, Nonsmooth Mechanics. Models, Dynamics and Control, 2016.
URL : https://hal.archives-ouvertes.fr/hal-01236953
Coefficient of restitution for viscoelastic spheres, Physical Review E, vol.78, issue.5, p.51304, 2008. ,
Multiple Impacts in Dissipative Granular Chains, Lecture Notes in Applied and Computational Mechanics, vol.72, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00908612
Continuous dependence on data for vibro-impact problems, Mathematical Models and Methods in Applied Sciences, vol.35, issue.1, pp.1-41, 2005. ,
One-dimensional collisions and Chebyschev polynomials, American Journal of Physics, vol.45, issue.3, pp.255-259, 1977. ,
, Liaisons unilatérales sans frottement et chocs inélastiques. Comptes-Rendus des Séances de l'Académie des Sciences, vol.296, pp.1473-1476, 1983.
Unilateral contact and dry friction in finite freedom dynamics, Nonsmooth Mechanics and Applications, vol.302, pp.1-82, 1988. ,
URL : https://hal.archives-ouvertes.fr/hal-01713847
A convergence result for a vibro impact problem with a general inertia operator, Nonlinear Dynamics, vol.58, issue.1-2, pp.361-384, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01552482
, Modeling contact in rocking structures with a nonsmooth dynamics approach. ECCOMAS Congress, VII European Congress on Computational Methods in Applied Sciences and Engineering, 2016.
Nonsmooth dynamics analysis of sticking impacts in rocking structures, Bulletin of Earthquake Engineering, vol.15, pp.2273-2304, 2017. ,
Comparisons of multiple-impact laws for multibody systems, Computational Mechanics, vol.43, pp.743-754, 2009. ,
Analysis of a generalized kinematic impact law for multibody-multicontact systems, with application to the planar rocking block and chains of balls, Multibody System Dynamics, vol.27, issue.3, pp.351-382, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00825573
Kinetic quasi-velocities in unilaterally constrained Lagragian mechanics with impacts and friction, Multibody System Dynamics, vol.32, issue.2, pp.175-216, 2014. ,
Shock absorption using linear particle chains with multiple impacts, ASME Journal of Applied Mechanics, vol.78, issue.3, p.31005, 2011. ,
Stability and Convergence of Mechanical Systems with Unilateral Constraints, Lecture Notes in Applied and Computational Mechanics, vol.36, 2008. ,
Impacts in multibody systems: modeling and experiments, Multibody System Dynamics, vol.20, issue.2, pp.163-176, 2008. ,
Study of Newton's cradle using a new discrete approach. Multibody System Dynamics, vol.33, pp.61-92, 2015. ,
A maximal monotone impact law for the 3-ball Newton's cradle, Multibody System Dynamics, vol.39, pp.79-94, 2017. ,
, Multibody Dynamics with Unilateral Contacts, Wiley Series in Nonlinear Science, 1996.
An introduction to impacts, CISM Courses and Lectures, vol.302, pp.45-101, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01716872
Some numerical methods in multibody dynamics: application to granular materials, European Journal of Mechanics A/Solids, vol.13, issue.4, pp.93-114, 1994. ,
Numerical aspects of the sweeping process, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.329-349, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01349847
Theoretical and experimental treatment of perfect multi-contact-collision, Proceedings of 3rd Asian Conf. Multibody Dynamics ACMD06, 2006. ,
Impulse dispersion in a tapered granular chain, Granular Matter, vol.4, issue.4, pp.167-174, 2003. ,
Pulse propagation in tapered granular chains: An analytic study, Physical Review E, vol.80, issue.3, p.31303, 2009. ,
DOI : 10.1103/physreve.80.031303
URL : http://orbilu.uni.lu/bitstream/10993/12324/1/09HarbolaEspositoPRE.pdf
Momentum and energy propagation in tapered granular chains, Granular Matter, vol.15, issue.6, pp.735-746, 2013. ,
DOI : 10.1007/s10035-013-0444-6
Pulse propagation in granular chains: The binary collision approximation, International Journal of Modern Physics B, vol.31, issue.10, p.1742016, 2017. ,
Impact of a projectile on a granular medium described by a collision model, Physical Review Letters, vol.99, issue.24, p.248001, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00905741
Granular medium impacted by a projectile: experiment and model, The European Physical Journal E: Soft Matter and Biological Physics, vol.30, issue.1, pp.43-54, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00664458
Frictionless multiple impacts in multibody systems: Part I. Theoretical framework, Proceedings of the Royal Society A, Mathematical, Physical and Engineering Sciences, vol.464, pp.3193-3211, 2008. ,
DOI : 10.1098/rspa.2008.0078
Energy dissipation and dispersion effects in a granular media, Physical Review E, vol.78, issue.3, p.31307, 2008. ,
Frictionless multiple impacts in multibody systems: Part II. Numerical algorithm and simulation results, Proceedings of the Royal Society A, Mathematical, Physical and Engineering Sciences, vol.465, pp.1-23, 2009. ,
Impact/contact dynamics in a disc-ball system, Proceedings of the Royal Society A, Mathematical, Physical and Engineering Sciences, vol.469, p.20120741, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00825597
Shock dynamics in granular chains: numerical simulations and comparisons with experimental tests, Granular Matter, vol.14, issue.3, pp.341-362, 2012. ,
DOI : 10.1007/s10035-012-0338-z
URL : https://hal.inria.fr/hal-00825561/file/nguyen2012.pdf
Nonsmooth dynamics of a 3D rigid body on a vibrating plate, Multibody System Dynamics, vol.32, issue.2, pp.217-239, 2014. ,
Dynamics of planar rocking-blocks with Coulomb friction and unilateral constraints: comparisons between experimental and numerical data, Multibody System Dynamics, vol.32, issue.1, pp.1-25, 2014. ,
DOI : 10.1007/s11044-013-9356-9
URL : https://hal.archives-ouvertes.fr/hal-01633235
Planar dynamics of a rigid body system with frictional impacts. II. Qualitative analysis and numerical simulations, Proceedings of the Royal Society A, Mathematical, Physical and Engineering Sciences, vol.465, pp.2267-2292, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00755926
Impact mechanics, 2004. ,
Numerical Methods for Nonsmooth Dynamical Systems. Applications in Mechanics and Electronics, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
DOI : 10.1007/978-3-540-75392-6
URL : https://hal.archives-ouvertes.fr/inria-00423530
The non-smooth contact dynamics method, Computer Methods in Applied Mechanics and Engineering, vol.177, issue.3-4, pp.235-257, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01390459
Projected event-capturing time-stepping schemes for nonsmooth mechanical systems with unilateral contact and Coulomb's friction, Computer Methods in Applied Mechanics and Engineering, vol.256, pp.224-250, 2013. ,
Energy conservation and dissipation properties of time-integration methods for nonsmooth elastodynamics with contact, ZAMM-J. Appl. Math. Mech./Z. Angew. Math. Mechanik, vol.96, issue.5, pp.585-603, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01235240
How does the ball chain work?, American Journal of Physics, vol.50, issue.11, pp.977-981, 1982. ,
Simple explanation of a well known collision experiment, American Journal of Physics, vol.49, issue.8, pp.761-764, 1981. ,
Dispersion-free linear chains, American Journal of Physics, vol.62, issue.3, pp.271-278, 1994. ,
New family of solitary waves in granular dimer chains with no precompression, Physical Review E, vol.83, issue.3, p.36606, 2011. ,
Collision of a 1-D column of beads with a wall, The European Physical Journal B, vol.5, pp.111-131, 1998. ,
