Bi-directional Search in QoS Routing, Proceedings of Quality for All: QoFIS, pp.102-111, 2003. ,
DOI : 10.1007/978-3-540-45188-4_11
An overview of constraint-based path selection algorithms for QoS routing, IEEE Communications Magazine, vol.40, issue.12, pp.50-55, 2002. ,
Optimal routing and traffic scheduling for multihop cellular networks using genetic algorithm, IEEE Transactions on Mobile Computing, vol.12, issue.11, pp.2274-2288, 2013. ,
Unicast QoS Routing Algorithms for SDN: A Comprehensive Survey and Performance Evaluation, IEEE Communications Surveys Tutorials, issue.99, pp.1-1, 2017. ,
TAMCRA: a tunable accuracy multiple constraints routing algorithm, Computer Communications, vol.23, issue.7, pp.667-679, 2000. ,
Hop-by-hop quality of service routing, Computer Networks, vol.37, issue.3, pp.407-423, 2001. ,
A niched pareto genetic algorithm for multiobjective optimization, IEEE CEC, vol.1, pp.82-87, 1994. ,
Multi-objective function optimisation using non-dominated sorting genetic algorithm, Evolutionary Comp, vol.2, issue.3, pp.221-248, 1994. ,
Comparison of Multiobjective Evolutionary Algorithms: Empirical Results, Evolutionary Computation, vol.8, issue.2, pp.173-195, 2000. ,
A fast and elitist multiobjective genetic algorithm: NSGA-II, IEEE Transactions on Evolutionary Computation, vol.6, issue.2, pp.182-197, 2002. ,
Many-objective evolutionary algorithm: Objective space reduction and diversity improvement, IEEE Transactions on Evolutionary Computation, vol.20, issue.1, pp.145-160, 2016. ,
An Evolutionary Many-Objective Optimization Algorithm Using Reference-Point-Based Nondominated Sorting Approach, Part I: Solving Problems With Box Constraints, IEEE Transactions on Evolutionary Computation, vol.18, issue.4, pp.577-601, 2014. ,
A path computation element (PCE)based architecture, Tech. Rep, 2006. ,
Path computation element (PCE) communication protocol (PCEP), 2009. ,
Concepts of exact qos routing algorithms, IEEE/ACM Transactions on Networking, vol.12, issue.5, pp.851-864, 2004. ,
Quality-of-service routing for supporting multimedia applications, IEEE Journal on Selected Areas in Communications, vol.14, issue.7, pp.1228-1234, 1996. ,
A bit error rate analysis for tcp traffic over parallel free space photonics, Telecommunication Systems, vol.56, issue.4, pp.455-466, 2014. ,
, The internet topology zoo
