Explanatory Diagnosis of an Ontology Stream via Reasoning About Actions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Explanatory diagnosis of an ontology stream aims to explain the changes hidden in the ontology stream by a sequence of actions. In this paper, we present a framework for explanatory diagnosis of an ontology stream, which allows the actions to be uncertain. In order to capture the semantics of actions, we introduce a new update operator and effect-guided bold-repair. By combining these operators with a query mechanism of description logics EL ++ supporting inconsistency-tolerant semantics, we present a formal definition for the explanatory diagnosis problem of ontology streams.
FAIA285-1596 (2).pdf (188.9 Ko) Télécharger le fichier
hal-01934918 , version 1 (26-11-2018)
Quan Yu, Hai Wan, Jiangtao Xu, Freddy Lecue, Liang Chang. Explanatory Diagnosis of an Ontology Stream via Reasoning About Actions. ECAI 2016 - 22nd European Conference on Artificial Intelligence, Sep 2016, The Hague, Netherlands. ⟨10.3233/978-1-61499-672-9-1596⟩. ⟨hal-01934918⟩
42 Consultations
35 Téléchargements
