New Pack Oriented Solutions for Energy-Aware Feasible Adaptive Real-Time Systems, Proc. 14th Int. Conf. Intell. Softw. Methodologies Tools Techn, pp.73-86, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01241877
New Reconfigurable Middleware for Adaptive RTOS in Ubiquitous Devices, Proc. 10th Int. Conf. Mobile Ubiquitous Comput. Syst. Services and Techn, pp.131-137, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01401716
Reconf-Pack: A Simulator for Reconfigurable Battery-Powered Real-Time Systems, Proc. 30th Europ Mod. Conf., University of Las Palmas. Spain, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01401706
Real-Time Scheduling of Reconfigurable Battery-Powered Multi-Core Platforms, Proc. 28th Int. Conf. Tools Artif. Intell, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01401712
Dynamic multiple-period reconfiguration of real-time scheduling based on timed DES supervisory control, IEEE Trans. Ind. Inform, vol.12, issue.1, pp.101-111, 2016. ,
Dynamic low-power reconfiguration of real-time systems with periodic and probabilistic tasks, IEEE Trans. Autom. Sci. Eng, vol.12, issue.1, pp.258-271, 2015. ,
Energy efficient scheduler of aperiodic jobs for real-time embedded systems, Int. J. Autom. Comput, pp.1-11, 2016. ,
Expressing embedded systems configurations at high abstraction levels with UML MARTE profile: Advantages, limitations and alternatives, J. Syst. Archit, vol.58, issue.5, pp.178-194, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00666014
Reconfiguration of Synchronous Real-Time Operating System, Int. J. Syst. Dynamics App, vol.2, issue.1, pp.114-132, 2013. ,
Energy-efficient task scheduling for multi-core platforms with per-core DVFS, J. Parallel Distrib. Comput, vol.86, issue.1, pp.71-81, 2015. ,
Heterogeneous vs homogeneous MPSoC approaches for a mobile LTE modem, Proc. Conf. Des. Autom, pp.184-189, 2010. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00436680
Elastic DVS management in processors with discrete voltage/frequency modes, IEEE Trans. Ind. Inform, vol.3, issue.1, pp.51-62, 2007. ,
An 80-tile sub-100-w teraflops processor in 65-nm cmos, IEEE Trans. Ind. Inform, vol.43, issue.1, pp.29-41, 2008. ,
Architecture for uniform (re) configuration and processing over embedded sensor and actuator networks, IEEE Trans. Ind. Inform, vol.10, issue.1, pp.53-60, 2014. ,
QoS-aware scheduling of servicesoriented internet of things, IEEE Trans. Ind. Inform, vol.10, issue.2, pp.1497-1505, 2014. ,
Capabilities of dynamic reconfiguration of multiagent-based industrial control systems, IEEE Trans. Syst, vol.40, issue.2, pp.213-223, 2010. ,
Scheduling algorithms for multiprogramming in a hard-real-time environment, J. ACM, vol.20, issue.1, pp.46-61, 1973. ,
Real-time scheduling of concurrent transactions in multidomain ring buses, IEEE Trans. Comput, vol.61, issue.9, pp.1311-1324, 2012. ,
Minimal energy fixed-priority scheduling for variable voltage processors, IEEE Trans. Comput.-Aided Design Integr. Circuits Syst, vol.22, issue.8, pp.1062-1071, 2003. ,
Reconfigurable CAN in real-time embedded platforms, Proc. 11th Int. Conf. Informat, pp.355-362, 2014. ,
Scheduling real-time tasks: Algorithms and complexity, Handbook of scheduling: Algorithms, models, and performance analysis, vol.22, 2004. ,
New Methodology for Feasible Reconfigurable Real-Time Network-on-Chip NoC, Proc. 11th Int. Conf. Softw. Eng. App, 2016. ,
Elastic task model for adaptive rate control, Proc. 19th Symp. Real-time Syst, pp.286-295, 1998. ,
Zero downtime reconfiguration of distributed automation systems: The ?cedac approach," in Holonic and Multi-Agent Systems for Manufacturing, pp.326-337, 2007. ,
, , 2013.
Static task scheduling algorithms based on greedy heuristics for battery-powered DVS systems, IEICE trans. Inform. syst, vol.93, issue.10, pp.2737-2746, 2010. ,
Energy-and performance-aware mapping for regular NoC architectures, IEEE Trans. Comput.-Aided Design Integr. Circuits Syst, vol.24, issue.4, pp.551-562, 2005. ,
New Extended Object Constraint Language for Adaptive Discrete Event Systems with Application to Recongurable Wireless Sensor Networks, IEEE Trans. Syst. Man. Cybern. Syst, 2017. ,
Multiagent framework for smart grids recovery, IEEE Trans. Syst. Man. Cybern. Syst, vol.47, issue.7, pp.1284-1300, 2017. ,
RWiN: new methodology for the development of reconfigurable WSN, IEEE Trans. Autom. Sci. Eng, vol.14, issue.1, pp.109-125, 2017. ,
R-TNCES: A novel formalism for reconfigurable discrete event control systems, IEEE Trans. Syst. Man. Cybern. Syst, vol.43, issue.4, pp.757-772, 2013. ,
R-Codesign: Codesign Methodology for Real-time Reconfigurable Embedded Systems Under Energy Constraints, IEEE Access, issue.99, 2018. ,
An Effective Load Balancing Task Allocation Algorithm using Task Clustering, Inter. J. Comput. Appl, vol.77, issue.7, 2013. ,
A smart algorithm for dynamic task allocation for distributed processing environment, Inter. J. Comput. Appl, vol.28, issue.2, pp.13-19, 2011. ,
